Bookmark
Subscribe
671
Unity MAD.EXE error messages
m.balastik
We've just recently upgraded from 3.1(5) to 4.0(4) and are seeing error messages in the Event Viewer to the effect of:
Event Type: Error
Event Source: MSExchangeDSAccess
Event Category: Topology
Event ID: 2102
Date: 11/2/2004
Time: 11:35:17 AM
User: N/A
Computer: PM-UNITY
Description:
Process MAD.EXE (PID=1484). All Domain Controller Servers in use are not responding:
<lists all DC's here - 13 of them>
For more information, click http://www.microsoft.com/contentredirect.asp.
Our system is set up as follows:
2nd Unity in AD (not set up for failover)
Exchange 2000 SP3 on box
Unity 4.0(4) - UM
We've investigated DNS issues and can't seem to find anything wrong.
Here are the messages that are also coming up in the Event Viewer:
Event Type: Information
Event Source: MSExchangeSA
Event Category: Monitoring
Event ID: 9095
Date: 11/2/2004
Time: 11:52:35 AM
User: N/A
Computer: PM-UNITY
Description:
The MAD Monitoring thread is initializing.
Event ID: 9096
Date: 11/2/2004
Time: 11:52:35 AM
User: N/A
Computer: PM-UNITY
Description:
The MAD Monitoring thread is initialized.
Event Type: Error
Event Source: Userenv
Event Category: None
Event ID: 1000
Date: 11/2/2004
Time: 11:51:19 AM
User: NT AUTHORITY\SYSTEM
Computer: PM-UNITY
Description:
Windows cannot obtain the domain controller name for your computer network. Return value (59).
Any input is appreciated.
Monica
5 Replies 5
kechambe
Level 7
Level 7
Having Exchange installed 'on-box' is not supported with 4.0 in a UM configuration. This doesn't explain the cause but rather than troubleshoot it you probably should move to a supported configuration.
Keith
We only use Exchange for Unity and have it in writing from Cisco that our configuration is okay. We will not be moving Exchange off box.
Monica
Hin Lee
Are you pointing the UNITY to the correct DNS server -> it should be one of the domain controllers that has AD-integrated zone? Do you have any Netlogon errors/warnings in the sytem logs?
It is pointing to the correct DNS server which is also one of the domain controllers.
There are no Netlogon errors/warnings in the system log.
Monica
Hin Lee
