Unity Port Group test failed
Deepak Kumar
My Unity and CUCM (11.5) are intergated using SSCP protocol. It was running form last few months but now I am facing an issue, Unity extensions are not reachable.
I started Tshoot and didn't find any changes in the configuration and testing a  "Port Group" is failed and error as below
" Failure reason: ErrorCannotEstablishWinsockConnection. connectToServer(10.10.x.xxx:2000)->0x80045A03"
Looking urgent help for the same.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Hi all,
Thanks for the reply. I didn't find any root cause for this issue but It is resolved after restarting the Unity.
I am happy but not sure why it happened. I checked all the configuration and it was ok.
Deepak Kumar
Deepak Kumar,
Chris Deren
Are the CUCM servers reachable from CUC?
Are the port names the same on both sides?
Why not use SIP, so much easier?
Thanks for your reply.
Ans: Yes both are reachable from both site.
Ans: Yes. It is the same
Ans: I am not sure. It was configured 3 years ago.
Deepak Kumar
Deepak Kumar,
I would re-confiugure the integration as SIP or re-build the SCCP ports to see if the error goes away.
Deepak Kumar
Hi all,
Deepak Kumar
Deepak Kumar,
