I am looking to do a CallManager and IM&P upgrade from version 12.0.1.22900-11 to latest 12.5(1) and also incorporate a platform refresh moving from current ESXi 6.0 to ESXi 7.0. I think that I can use PCD to perform the upgrade and migration though could do with some guidance for the best method. There are 2 options: -
1/ PCD migration and upgrade, I have done these in the past when migrating from physical to virtual and once the pre-requisites are met then they went quite smoothly. I think this is a good method and possibly my preferred option however I'd like to have your input?
2/ New install and data import, I presume this also uses PCD to build the cluster and import the data . I think this would be difficult given that I have a 24/7 user environment which is a hospital though I don't know what is really involved? I don't want to change my IP's if possible and I can't see a way of doing this without doing so.
I'd like to know the easiest method and also which one would have the least downtime? I have a cluster of 7 servers 1 pub, 3 subs, 3 back subs/tftp.
