VG204 registered with CME
h_hammad
How can I add VG204 to CME as sccp and configure the analogue ports on the VG throught CME , Cisco documents not helping much , also Is there a way I can login to CME through web ?
Thanks you gents
2 Accepted Solutions
yahsiel2004
Level 7
Level 7
Here is an example of the configuration you will need to do. (This is not layed out in exact order)
On the VG204
Interface VLAN 1
IP Address 10.0.0.1
sccp local VLAN 1
sccp ccm 1.1.1.1 identifier 1 priority 1 <----- The IP Address here would be the IP Address of your CUCME
sccp
sccp ccm group 1
bind interface VLAN 1
associate ccm 1 priority 1
stcapp ccm-group 1
stcapp
ccm-manager config server 1.1.1.1
ccm-manager config
ccm-manager sccp
ccm-manager sccp local VLAN 1
For every FXS port create a dial-peer as seen below:
Dial-peer voip 1 pots
service stcapp <---- This is what puts the FXS port under SCCP control.
port 0/0/0
On the CUCME (Pre-configured)
Configure the VG204 Gateway on CUCME as seen below:
voice-gateway system  1
network-locale FR
type VG224
mac-address 1234.5678.9999
voice-port 0-23
create cnf-files
For the analog phone you can configure auto-registration if you wish to or manually add the phones.
Automatically register ephones:
Under the Telephony-service add the following command
auto assign 1 to 24 type anl
— Use the type keyword if you have other phone types in the system and you want only  the analog endpoints to be assigned to ephone-dns automatically.
To add a ephone manually read the following:
The VG202 and VG204 voice gateways use the MAC address of the Skinny  Call Control Protocol (SCCP) local interface to define unique MAC  addresses for each voice port by using the last 9 digits of the SCCP  local interface of the voice gateway.
For example, if the source interface MAC address is 000C.8639.5833, the  MAC address of the voice port MAC address will be C863.9583.3XXX. In the  preceding example, the last 9 digits of the SCCP of the local VG202 or  VG204 voice gateway become the first 9 digits of the voice port MAC  address after dropping the leading 000.
The last 3 digits of the voice port MAC address is the slot number  (3-bit) + subunit number (2-bit) + port number (7-bit) in hexadecimal  format. You combine the digits to get the last three MAC address digits.
For example, the voice-port 0/0 is slot number 0 (000): subunit 0 (00) and port number 0 (0000000). By stringing the digits together, you get the following: 0000 0000 0000 = 0 0 0. This means that if the source interface MAC address is 001f.cac3.b3f8, the MAC address of voice port 0/0 will be 1FCAC3b3f8000
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_voip_ps2250_TSD_Products_Configuration_Guide_Chapter.html#wp1059863
Ephone example:
ephone 1
device-security-mode none
mac-address 1234.5678.9000
button 1:1
ephone 2
mac-address 1234.5678.9001
button 1:1
Hope this helps
Yosh
HTH Regards, Yosh
You can download the CUCME GUI from Cisco. Just verify that you have enough flash memory to store the files.
HTH Regards, Yosh
19 Replies 19
yahsiel2004
Level 7
Level 7
On the VG204
Interface VLAN 1
IP Address 10.0.0.1
sccp local VLAN 1
sccp
sccp ccm group 1
stcapp ccm-group 1
stcapp
ccm-manager config
ccm-manager sccp
port 0/0/0
network-locale FR
type VG224
voice-port 0-23
create cnf-files
Ephone example:
ephone 1
button 1:1
ephone 2
button 1:1
Hope this helps
Yosh
HTH Regards, Yosh
HTH Regards, Yosh
Thank you too much yahsiel , you are perfect , I will try and tell you .
Thanks again
After apply the configuration ,  I am getting busy tone when I try to call from the analogue phone , Any clue ?
Thanks again for you help
Are the phones registered with CME? Do a "show ephone" and verify if the analog phones are registered. If not post a config of the VG204 and the CUCME.
Yosh
HTH Regards, Yosh
scheduler allocate 20000 1000
end
interface FastEthernet0/0
ip address 172.16.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.1
control-plane
voice-port 0/0
timeouts ringing infinity
voice-port 0/1
voice-port 0/2
voice-port 0/3
ccm-manager config server 172.16.1.1
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 172.16.1.1 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
bind interface FastEthernet0/0
dial-peer voice 999000 pots
service stcapp
port 0/0
dial-peer voice 999001 pots
service stcapp
port 0/1
dial-peer voice 999002 pots
service stcapp
port 0/2
dial-peer voice 999003 pots
service stcapp
port 0/3
dial-peer voice 1 pots
service stcapp
port 0/0
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
exception data-corruption buffer truncate
end
Router#
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call service stop maintain-registration
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
voice class h323 1
  h225 timeout tcp establish 3
hw-module pvdm 0/0
redundancy
interface Loopback0
ip address 10.1.97.250 255.255.255.255
interface GigabitEthernet0/0
ip address 10.1.96.254 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id g0/0 ipaddr 10.1.96.254 1719
h323-gateway voip h323-id g0/0
h323-gateway voip bind srcaddr 10.1.96.254
interface GigabitEthernet0/1
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip http server
no ip http secure-server
ip route 10.0.0.0 255.0.0.0 10.1.96.1
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
dial-peer voice 5555555 pots
dial-peer voice 33 pots
destination-pattern 9T
prefix 9
dial-peer voice 5 voip
destination-pattern 1..
session target ipv4:10.1.96.10
gateway
timer receive-rtp 1200
gatekeeper
shutdown
telephony-service
max-dn 4
auto assign 1 to 1
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn  1
number 123456
network-locale AE
type VG204
mac-address 001F.CAF1.BC88
voice-port 0-3
create cnf-files
-------------------------------------------------Vg204-----------------------------------
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
voice-port 0/0
voice-port 0/1
voice-port 0/2
voice-port 0/3
ccm-manager config
ccm-manager sccp
sccp
sccp ccm group 1
service stcapp
port 0/0
service stcapp
port 0/1
service stcapp
port 0/2
service stcapp
port 0/3
service stcapp
port 0/0
and also show ephone shows nothing
Thank you again
The reason why nothing shows up when you do a show ephone is because on your configuration there is no ephone configured and CUCME is not configured all the way. Below is the configuration you're missing.
CUCME configuration changes:
telephony-service
max-dn 4
max-ephone 4
ip source-address 172.16.1.1 port 2000
auto assign 1 to 1
stcapp ccm-group 1
stcapp
ephone 1
mac-address (VG204 Fa0/0 MAC Address)
button 1:1
Verify that the MAC Address configured under the "voice-gateway system  1" is the MAC Address of VG204 Fa0/0 interface.
Try the configuration changes as seen above and just note that I put max-ephone 4 which should be changed to a higher number if you want more than 4 ephone configured in CUCME. Once changes have been made do a show ephone and verify if you see the ephone registered.
Hope this helps
Yosh
HTH Regards, Yosh
Also for got to add the "create-cnf files" under the telephony-service after you make the changes and if you are trying to do auto registration change the "auto assign 1 to 1" to "auto assign 1 to 24 type anl"
Don't forget that you owuld need to change the last 2 of the ephones MAC Address to the voice-port number.
Example:
ephone- 1
mac-address 001F.CAF1.BC00 (This would register voice-port 0/0)
button 1:1
Yosh
HTH Regards, Yosh
Thank you Yosh ,
I have done that but I am not hearing dial tone on the analogue phone connected to the VG204
Here is the show ephone
Vgateway-1#SH EPHone
ephone-1[0] Mac:001F.CAF1.BC88 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGI
STERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 res
et_sent:0 paging 0 debug:0 caps:0
IP:172.16.1.2 * 50988 Unknown 0  keepalive 0 max_line 0 available_line 0
button 1: cw:1 ccw:(0)
  dn 1  number 123456 CH1   DOWN
Preferred Codec: g711ulaw
Lpcor Type: none
ephone-2[1] Mac:FCAF.1BC8.8FFF TCP socket:[-1] activeLine:0 whisperLine:0 DECEAS
ED
et_sent:0 paging 0 debug:0 caps:1
IP:172.16.1.2 * 23345 Unknown 30032  keepalive 16 max_line 0 available_line 1
Lpcor Type: none
ephone-3[2] Mac:FCAF.1BC8.8000 TCP socket:[2] activeLine:0 whisperLine:0 REGISTE
RED in SCCP ver 9/9 max_streams=1
et_sent:0 paging 0 debug:0 caps:8
IP:172.16.1.2 * 45594 SCCP Gateway (AN)  keepalive 0 max_line 1 available_line 1
port 0/0/0
Lpcor Type: none
ephone-4[3] Mac:FCAF.1BC8.8001 TCP socket:[-1] activeLine:0 whisperLine:0 DECEAS
ED
IP:172.16.1.2 * 49079 SCCP Gateway (AN)  keepalive 15 max_line 1 available_line
port 0/0/1
Lpcor Type: none
ephone-5[4] Mac:FCAF.1BC8.8003 TCP socket:[-1] activeLine:0 whisperLine:0 DECEAS
ED
IP:172.16.1.2 * 45958 SCCP Gateway (AN)  keepalive 7 max_line 1 available_line 1
port 0/0/3
Lpcor Type: none
ephone-6[5] Mac:FCAF.1BC8.8002 TCP socket:[1] activeLine:0 whisperLine:0 REGISTE
IP:172.16.1.2 * 19441 SCCP Gateway (AN)  keepalive 0 max_line 1 available_line 1
port 0/0/2
Lpcor Type: none
Vgateway-1#
I see that ephone 3 port 0/0/0 and ephone 6 port 0/0/3 is registered but I don't see a ephone-dn assinged to the ephones. Configure an ephone-dn to these ephones and verify if you have dial tone.
Also verify the MAC Address you are using to create the ephones. From the configuration you sent me before you should be using MAC Address "001F.CAF1.BC88" and only the last 2 numbers should be changed to match the voiceport you have. Example below:
network-locale AE
type VG204
voice-port 0-3
create cnf-file
voice-port 0/0
ephone
mac-address 001F.CAF1.BC00 (The last two number is 00 to match voice-port 0/0)
button 1:1
Yosh
HTH Regards, Yosh
Yosh , I connect the phone on P0/0/3 and I can hear dial tone , but I cant dial to other phone inside the system yet
Thank you for your help
Here are some debug
It say skinny register rejected !!
92
*Feb  2 05:01:22.107: ephone-(2) Allow any Skinny Server IP address 172.16.1.1
*Feb  2 05:01:22.107: Skinny Phone Limit Exceeded 4/4
*Feb  2 05:01:22.107: Skinny register (phones=4/4/6) REJECT from IP 172.16.1.2
*Feb  2 05:02:11.111: New Skinny socket accepted [1] from 0, sub 1 (6 active)
*Feb  2 05:02:11.111: sin_family 2, sin_port 18474, in_addr 172.16.1.2
*Feb  2 05:02:11.111: skinny_add_socket 1 172.16.1.2 18474
*Feb  2 05:02:11.111: ephone-(2)[7] StationRegisterMessage (4/4/6) from 172.16.1
.2
*Feb  2 05:02:11.111: ephone-(2)[7] Register StationIdentifier DeviceName AN1FCA
F1BC88FFF
*Feb  2 05:02:11.111: ephone-(2)[7] StationIdentifier Instance 1    deviceType 3
0032
*Feb  2 05:02:11.111: fSkinnyStationRegister deviceType 30032 protocolVer = 0x6
*Feb  2 05:02:11.111: StationJoinAndDirectTransferFeatureSupportMask set disable
*Feb  2 05:02:11.111: StationDisableJoinOnTheSameLineFeatureMask set enable
*Feb  2 05:02:11.111: StationDisableJoinAcrossLineFeatureMask set enable
*Feb  2 05:02:11.111: StationDisableDirectTransferOnTheSameLineFeatureMask set e
nable
*Feb  2 05:02:11.111: StationDisableDirectTransferAcrossLineFeatureMask set enab
le
*Feb  2 05:02:11.111: ephone-2[1/-1][AN1FCAF1BC88FFF]:stationIpAddr 172.16.1.2
*Feb  2 05:02:11.111: ephone-2[1/-1][AN1FCAF1BC88FFF]:maxStreams 0
*Feb  2 05:02:11.111: ephone-2[1/-1][AN1FCAF1BC88FFF]:From Phone raw protocol Ve
r 0x6
*Feb  2 05:02:11.111: ephone-2[1/-1][AN1FCAF1BC88FFF]:protocol Ver 0x6
*Feb  2 05:02:11.111: ephone-2[1/-1][AN1FCAF1BC88FFF]:phone-size 36104 dn-size 9
92
*Feb  2 05:02:11.111: ephone-(2) Allow any Skinny Server IP address 172.16.1.1
*Feb  2 05:02:11.111: Skinny Phone Limit Exceeded 4/4
*Feb  2 05:02:11.111: Skinny register (phones=4/4/6) REJECT from IP 172.16.1.2
*Feb  2 05:03:00.115: New Skinny socket accepted [1] from 0, sub 1 (7 active)
*Feb  2 05:03:00.115: sin_family 2, sin_port 39656, in_addr 172.16.1.2
*Feb  2 05:03:00.119: skinny_add_socket 1 172.16.1.2 39656
*Feb  2 05:03:00.119: ephone-(2)[8] StationRegisterMessage (4/4/6) from 172.16.1
.2
*Feb  2 05:03:00.119: ephone-(2)[8] Register StationIdentifier DeviceName AN1FCA
F1BC88FFF
*Feb  2 05:03:00.119: ephone-(2)[8] StationIdentifier Instance 1    deviceType 3
0032
*Feb  2 05:03:00.119: fSkinnyStationRegister deviceType 30032 protocolVer = 0x6
*Feb  2 05:03:00.119: StationJoinAndDirectTransferFeatureSupportMask set disable
*Feb  2 05:03:00.119: StationDisableJoinOnTheSameLineFeatureMask set enable
*Feb  2 05:03:00.119: StationDisableJoinAcrossLineFeatureMask set enable
*Feb  2 05:03:00.119: StationDisableDirectTransferOnTheSameLineFeatureMask set e
nable
*Feb  2 05:03:00.119: StationDisableDirectTransferAcrossLineFeatureMask set enab
le
*Feb  2 05:03:00.119: ephone-2[1/-1][AN1FCAF1BC88FFF]:stationIpAddr 172.16.1.2
*Feb  2 05:03:00.119: ephone-2[1/-1][AN1FCAF1BC88FFF]:maxStreams 0
*Feb  2 05:03:00.119: ephone-2[1/-1][AN1FCAF1BC88FFF]:From Phone raw protocol Ve
r 0x6
*Feb  2 05:03:00.119: ephone-2[1/-1][AN1FCAF1BC88FFF]:protocol Ver 0x6
*Feb  2 05:03:00.119: ephone-2[1/-1][AN1FCAF1BC88FFF]:phone-size 36104 dn-size 9
92
*Feb  2 05:03:00.119: ephone-(2) Allow any Skinny Server IP address 172.16.1.1
*Feb  2 05:03:00.119: Skinny Phone Limit Exceeded 4/4
*Feb  2 05:03:00.119: Skinny register (phones=4/4/6) REJECT from IP 172.16.1.2
*Feb  2 05:03:59.123: New Skinny socket accepted [1] from 0, sub 1 (8 active)
*Feb  2 05:03:59.123: sin_family 2, sin_port 53555, in_addr 172.16.1.2
*Feb  2 05:03:59.123: skinny_add_socket 1 172.16.1.2 53555
*Feb  2 05:03:59.123: ephone-(2)[9] StationRegisterMessage (4/4/6) from 172.16.1
.2
*Feb  2 05:03:59.123: ephone-(2)[9] Register StationIdentifier DeviceName AN1FCA
F1BC88FFF
*Feb  2 05:03:59.123: ephone-(2)[9] StationIdentifier Instance 1    deviceType 3
0032
*Feb  2 05:03:59.123: fSkinnyStationRegister deviceType 30032 protocolVer = 0x6
*Feb  2 05:03:59.123: StationJoinAndDirectTransferFeatureSupportMask set disable
*Feb  2 05:03:59.123: StationDisableJoinOnTheSameLineFeatureMask set enable
*Feb  2 05:03:59.123: StationDisableJoinAcrossLineFeatureMask set enable
*Feb  2 05:03:59.123: StationDisableDirectTransferOnTheSameLineFeatureMask set e
nable
*Feb  2 05:03:59.123: StationDisableDirectTransferAcrossLineFeatureMask set enab
le
*Feb  2 05:03:59.123: ephone-2[1/-1][AN1FCAF1BC88FFF]:stationIpAddr 172.16.1.2
*Feb  2 05:03:59.123: ephone-2[1/-1][AN1FCAF1BC88FFF]:maxStreams 0
*Feb  2 05:03:59.123: ephone-2[1/-1][AN1FCAF1BC88FFF]:From Phone raw protocol Ve
r 0x6
*Feb  2 05:03:59.123: ephone-2[1/-1][AN1FCAF1BC88FFF]:protocol Ver 0x6
*Feb  2 05:03:59.123: ephone-2[1/-1][AN1FCAF1BC88FFF]:phone-size 36104 dn-size 9
92
*Feb  2 05:03:59.123: ephone-(2) Allow any Skinny Server IP address 172.16.1.1
*Feb  2 05:03:59.123: Skinny Phone Limit Exceeded 4/4
*Feb  2 05:03:59.123: Skinny register (phones=4/4/6) REJECT from IP 172.16.1.2
*Feb  2 05:04:36.131: New Skinny socket accepted [1] from 0, sub 1 (7 active)
*Feb  2 05:04:36.131: sin_family 2, sin_port 42997, in_addr 172.16.1.2
*Feb  2 05:04:36.131: skinny_add_socket 1 172.16.1.2 42997
*Feb  2 05:04:36.131: ephone-(2)[5] StationRegisterMessage (4/4/6) from 172.16.1
.2
*Feb  2 05:04:36.131: ephone-(2)[5] Register StationIdentifier DeviceName AN1FCA
F1BC88FFF
*Feb  2 05:04:36.131: ephone-(2)[5] StationIdentifier Instance 1    deviceType 3
0032
*Feb  2 05:04:36.131: fSkinnyStationRegister deviceType 30032 protocolVer = 0x6
*Feb  2 05:04:36.131: StationJoinAndDirectTransferFeatureSupportMask set disable
*Feb  2 05:04:36.131: StationDisableJoinOnTheSameLineFeatureMask set enable
*Feb  2 05:04:36.131: StationDisableJoinAcrossLineFeatureMask set enable
*Feb  2 05:04:36.131: StationDisableDirectTransferOnTheSameLineFeatureMask set e
nable
*Feb  2 05:04:36.131: StationDisableDirectTransferAcrossLineFeatureMask set enab
le
*Feb  2 05:04:36.131: ephone-2[1/-1][AN1FCAF1BC88FFF]:stationIpAddr 172.16.1.2
*Feb  2 05:04:36.131: ephone-2[1/-1][AN1FCAF1BC88FFF]:maxStreams 0
*Feb  2 05:04:36.131: ephone-2[1/-1][AN1FCAF1BC88FFF]:From Phone raw protocol Ve
r 0x6
*Feb  2 05:04:36.131: ephone-2[1/-1][AN1FCAF1BC88FFF]:protocol Ver 0x6
*Feb  2 05:04:36.131: ephone-2[1/-1][AN1FCAF1BC88FFF]:phone-size 36104 dn-size 9
92
*Feb  2 05:04:36.131: ephone-(2) Allow any Skinny Server IP address 172.16.1.1
*Feb  2 05:04:36.131: Skinny Phone Limit Exceeded 4/4
*Feb  2 05:04:36.131: Skinny register (phones=4/4/6) REJECT from IP 172.16.1.2
92
.2
F1BC88FFF
0032
nable
le
r 0x6
92
.2
F1BC88FFF
0032
nable
le
r 0x6
92
.2
F1BC88FFF
0032
nable
le
r 0x6
92
.2
F1BC88FFF
0032
nable
le
r 0x6
92
It's being rejected because you have more than 4 ephones in the system. You will need to increase the ephone limit from 4 to however many phones you want your system to allow. See example below
telephony-service
max-ephone 10
Yosh
HTH Regards, Yosh
now phone is registered with the CME , now how can I configure dial peer inside the CME to point to the analogue phone on the VG204 ?
Thank you
