What is required to run CUCME 7/8 on 2811
simonmossman
Hi all
Can someone please help as I have a cisco 2811 running c2800nm-spservicesk9-mz.124-22.T.bin and want to use it for local phone connectivity with CUCME. Do i just need to install CUCME CME 8.0 files for IOS 15.0(1)XA and the CME 8.0 Updated GUI files for IOS 15.0(1)XA.
Once these are loaded i assume it is just a case of adding the ephones and the users etc.
Simon
paolo bevilacqua
The files are not mandatory. If you do not use the GU, you do not need them.
so as long as I do not use the GUI then I can run CME as normal on this ios? Then just a case of entering all the ephones via CL config? I also need to add a CUE module for VM. Is it simply a case of adding the license files to get this working....after correct config loaded?
