XMPP Federation with Presence 8
nandocesar
I would like to know if it´s possible to federate Presence 8 with Spark IM via XMPP?
Anyone already done that?
Fernando
8 Replies 8
MICHAEL HUNTER
Level 4
Level 4
I am trying to do the same thing here with CUPS version 8.0.2.10000-30. Please let me know if you get an answer back on this one. We are trying to integrate with Spark and do some beta testing for Cisco.
Thanks - Mike
Joseph Hardy
CUPS can federate with any XMPP compliant server.  However it is important to know which have been officially tested.
Supported Federations with IM and Presence Service Release 9.1(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/im_presence/compatibility/9_1_1/IM_P_Compatibility.html#wp171300
I can also confirm at least 3 other customers have interdomain XMPP federation working with Spark Openfire server.
There is a case senstivity bug in 8.0 to watch out for.
CSCti98431 - Make startup scripts case insensitive when querying processnode tbl
cowherjohn
We have been trying for a month to federate CUPS 9.1 with a business partner running the latest Openfire 3.9.1.  We have  never seen any presence via our clients on either end.
We have a DMZ intercluster peer, connecting to our internal cups server, we federate with Cisco and two other partners.
The new partner with Openfire has an external listening IP address natting thru netscaler to the internal Openfire server IP.
New parnter outbound xmpp traffic is sent via a second- external - sending IP address.
We have wireshark on the Openfire server and see traffic from our DMZ Cups server,  we can see traffic by doing captures on our cups server
we can resolve them on our cups servers both, with the utils network host and xmpp srv , and they can resolve our records on their server,
Can anyone share Openfire config, ?
I don't have access to Openfire and can't help with it's configuraiton.
The fact that XMPP federation is working with other enterprises, tells my your CUP/IMP server and DNS is configured correctly and the problem must be on the Openfire side.
My best guess here is the dialback for sever verification is failing.  The dialback secret is a password, it can be anything.  To over simplify, the recieving XMPP server verifies the identity of the connectinig server by comparing the dial back secret provided in the initial connection with the dialback secret provided by DNS lookup and a return connection.  If they match it is very likely the connection is from a legitmate server.
Reference:
http://xmpp.org/extensions/xep-0220.html
Do you see a successful dialback connection in your packet capture?
Next step will be looking at logs to determine what is going wrong.  I suggest opening a service request for assistance with this.
External/DMZ Cups capture Openfire IP is 66.192.59.27
From DMZ cups :
       6144 Mbytes RAM
admin:utils network capture host all 66.192.59.27
Executing command with options:
size=128                count=1000              interface=eth0
src=                    dest=                   port=
ip=66.192.59.27
11:36:41.446808 IP SDDMZCUPS01.advance-auto.com.36225 > im.gpi.com.xmpp-server: S 2299544096:2299544096(0) win 5840
11:36:41.474214 IP im.gpi.com.xmpp-server > SDDMZCUPS01.advance-auto.com.36225: S 655306752:655306752(0) ack 2299544097 win 8190
11:36:41.474237 IP SDDMZCUPS01.advance-auto.com.36225 > im.gpi.com.xmpp-server: . ack 1 win 5840
11:36:41.474376 IP SDDMZCUPS01.advance-auto.com.36225 > im.gpi.com.xmpp-server: P 1:197(196) ack 1 win 5840
11:36:41.502241 IP im.gpi.com.xmpp-server > SDDMZCUPS01.advance-auto.com.36225: . ack 197 win 10914
11:36:56.307951 IP SDDMZCUPS01.advance-auto.com.36225 > im.gpi.com.xmpp-server: F 197:197(0) ack 1 win 5840
11:36:56.308244 IP SDDMZCUPS01.advance-auto.com.36239 > im.gpi.com.xmpp-server: S 1312879172:1312879172(0) win 5840
11:36:56.358497 IP im.gpi.com.xmpp-server > SDDMZCUPS01.advance-auto.com.36239: S 2886681851:2886681851(0) ack 1312879173 win 8190
11:36:56.358529 IP SDDMZCUPS01.advance-auto.com.36239 > im.gpi.com.xmpp-server: . ack 1 win 5840
11:36:56.358712 IP SDDMZCUPS01.advance-auto.com.36239 > im.gpi.com.xmpp-server: P 1:197(196) ack 1 win 5840
11:36:56.401292 IP im.gpi.com.xmpp-server > SDDMZCUPS01.advance-auto.com.36239: . ack 197 win 10914
11:36:56.464071 IP im.gpi.com.xmpp-server > SDDMZCUPS01.advance-auto.com.36225: . ack 198 win 10914
11:37:08.797172 IP im.gpi.com.xmpp-server > SDDMZCUPS01.advance-auto.com.36225: F 1:1(0) ack 198 win 10914
11:37:08.797221 IP SDDMZCUPS01.advance-auto.com.36225 > im.gpi.com.xmpp-server: . ack 2 win 5840
11:37:08.797174 IP im.gpi.com.xmpp-server > SDDMZCUPS01.advance-auto.com.36225: R 2:2(0) ack 198 win 9300
Internal Cups Capture:
From internal cups:
src=                    dest=                   port=
ip=66.192.59.27
11:15:12.015648 IP SDCUPSPRD01.corp.advancestores.com.49228 > im.gpi.com.xmpp-server: S 829070194:829070194(0) win 5840
11:15:12.084275 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49228: S 2385419654:2385419654(0) ack 829070195 win 8190
11:15:12.084309 IP SDCUPSPRD01.corp.advancestores.com.49228 > im.gpi.com.xmpp-server: . ack 1 win 5840
11:15:12.084537 IP SDCUPSPRD01.corp.advancestores.com.49228 > im.gpi.com.xmpp-server: P 1:199(198) ack 1 win 5840
11:15:12.158564 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49228: . ack 199 win 10912
11:15:26.807876 IP SDCUPSPRD01.corp.advancestores.com.49228 > im.gpi.com.xmpp-server: F 199:199(0) ack 1 win 5840
11:15:26.808714 IP SDCUPSPRD01.corp.advancestores.com.49239 > im.gpi.com.xmpp-server: S 1531433294:1531433294(0) win 5840
11:15:26.866636 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49239: S 1126490627:1126490627(0) ack 1531433295 win 8190
11:15:26.866671 IP SDCUPSPRD01.corp.advancestores.com.49239 > im.gpi.com.xmpp-server: . ack 1 win 5840
11:15:26.866808 IP SDCUPSPRD01.corp.advancestores.com.49239 > im.gpi.com.xmpp-server: P 1:199(198) ack 1 win 5840
11:15:26.937532 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49239: . ack 199 win 10912
11:15:26.980225 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49228: . ack 200 win 10912
11:15:41.917295 IP SDCUPSPRD01.corp.advancestores.com.49239 > im.gpi.com.xmpp-server: F 199:199(0) ack 1 win 5840
11:15:42.079636 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49239: . ack 200 win 10912
11:16:12.189414 IP SDCUPSPRD01.corp.advancestores.com.49280 > im.gpi.com.xmpp-server: S 3697954360:3697954360(0) win 5840
11:16:12.240962 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49280: S 1241659010:1241659010(0) ack 3697954361 win 8190
11:16:12.240992 IP SDCUPSPRD01.corp.advancestores.com.49280 > im.gpi.com.xmpp-server: . ack 1 win 5840
11:16:12.241116 IP SDCUPSPRD01.corp.advancestores.com.49280 > im.gpi.com.xmpp-server: P 1:199(198) ack 1 win 5840
11:16:12.280779 IP im.gpi.com.xmpp-server > SDCUPSPRD01.corp.advancestores.com.49280: . ack 199 win 10912
This from openfire log:
openfire.server.ServerDialback - ServerDialback: OS - Ignoring unexpected answer in validation from: advance-auto.com id: 2A4F48A7CC12 for domain: im.gpi.com answer:http://etherx.jabber.org/streams">
Their openfire server name is im.gpi.com
I think you are right on the money with dialback failing I just cannot figure out where.
I think the problem here is outbound XMPP traffic is not relayed through the inter-cluster peer.
Try configuring the same dialback secret on SDCUPSPRD01 and SDDMZCUPS01.
The dialback secrets were the same, but I just re-entered them to assure that was the case.
Seeing same warning in logs on Openfire server.. Still no presence either way.
From the internal cups xmpp federation logs we can see the connection make and then timeout:
debug| SSCommandProcessor.cpp:1650 Trying next rule: Host: im.gpi.com, Director: cm-4-xmpp-fed-s2s-outd, SRV: (nil), Port: 5269
09:12:38.594 |b3d4cb90| info| XMPPServerOutDir Resolved 'im.gpi.com' using port 5269.
09:12:38.594 |b3d4cb90| debug| XMPPServerOutDir No SASL configuration.
09:12:38.594 |b3d4cb90| debug| XMPPSoutTranscoder{28B509D539AF} New outgoing xcoder: 28B509D539AF
09:12:38.594 |b3d4cb90| debug| XMPPServerOutDir.cpp:615 Adding Connection: host - im.gpi.com, transcoder - 28B509D539AF
09:12:38.594 |b44cfb90| debug| BasicSocket.cpp:251 connect fd 47 from 68.70.98.23:56152 to 66.192.59.27:5269 EINPROGRESS
09:12:38.618 |b44cfb90| debug| XMPPSoutTranscoder{28B509D539AF} onSocketConnect
09:12:38.618 |b44cfb90| debug| XMPPStream.cpp:1323 onConnected - starting timeout for stream:stream element
09:12:41.614 |b454fb90| debug| XMPPStream.cpp:2267 timeout waiting for stream:stream element
09:12:41.614 |b454fb90| debug| XMPPStream.cpp:1343 onClose. XML Stream is gone. 0
09:12:41.614 |b454fb90| debug| XMPPStream.cpp:1368 Firing onClose event
