Hello all,
I am facing an issue when trying to upgrade from CUCM 7.1.5.30000-1 to 9.1(2) over UCS following the jump upgrade procedure.
I have installed 7.1.5 CUCM software on the UCS using the 9.1(2) ova. (two nodes cluster), and after that restored the CUCM backup.
I have loaded "ciscocm.refresh_upgrade_v1.3.cop" file before the upgrade on both nodes.
The connectivity with NTP server is good.
The upgrade file I am using is "UCSInstall_UCOS_9.1.2.11900-12.sgn".
The installation begins on Publisher but after three hours and when it is ending it fails. I have checked the installation logs and this is what it shows:
05/23/2014 17:45:51 component_install|(CAPTURE) Fri May 23 17:41:46 2014 cm-dbl-install DEBUG: cm-dbl-install [0]|<LVL::Debug>
05/23/2014 17:45:51 component_install|(CAPTURE) Fri May 23 17:41:46 2014 cm-dbl-install DEBUG: <--|<LVL::Debug>
05/23/2014 17:45:51 component_install|File:/opt/cisco/install/bin/component_install:756, Function: exec_progmeter(), /opt/cisco/install/bin/progmeter failed (1)|<LVL::Error>
05/23/2014 17:45:51 appmanager.sh|Internal Error, File:/usr/local/bin/base_scripts/appmanager.sh:269, Function: refresh_upgrade(), failed to refresh_upgrade infrastructure_post components|<LVL::Critical>
05/23/2014 17:45:51 post_install|File:/opt/cisco/install/bin/post_install:911, Function: install_applications(), /usr/local/bin/base_scripts/appmanager.sh -refresh-upgrade failed (1)|<LVL::Error>
05/23/2014 17:45:51 post_install|Exiting with result 1|<LVL::Info>
05/23/2014 17:45:51 post_install|INSTALL_TYPE="Refresh Upgrade"|<LVL::Debug>
05/23/2014 17:45:51 post_install|Process refresh upgrade failure|<LVL::Info>
05/23/2014 17:45:51 post_install|(CAPTURE) Mail notification cancelled - smtp server address for email not found! [/usr/local/platform/conf/platformConfig.xml]|<LVL::Debug>
05/23/2014 17:45:51 post_install|Retore grub.conf from grub.conf.recovery|<LVL::Info>
05/23/2014 17:45:51 post_install|Copy recovery file, /grub/boot/grub/grub.conf.recovery, to /grub/boot/grub/grub.conf|<LVL::Debug>
05/23/2014 17:45:51 post_install|Retore of grub.conf complete|<LVL::Info>
05/23/2014 17:45:51 post_install|Invalidate upgrade partition|<LVL::Info>
05/23/2014 17:45:51 post_install|Removing master RPM|<LVL::Debug>
05/23/2014 17:45:52 post_install|Removing /etc/opt/cisco/install.conf|<LVL::Debug>
05/23/2014 17:45:52 post_install|Invalidate any product configuration file|<LVL::Debug>
05/23/2014 17:45:52 post_install|Setting product and deployment version attributes in /etc/opt/cisco/install/conf/callmanager_product.conf to 0.0.0.0000-0000|<LVL::Debug>
05/23/2014 17:45:52 post_install|Cleanup refresh upgrade staging areas|<LVL::Debug>
05/23/2014 17:46:14 post_install|Parse argument status=upgrade.stage.error|<LVL::Debug>
05/23/2014 17:46:14 post_install|_set_upgrade_status_attribute: status set to upgrade.stage.error|<LVL::Debug>
05/23/2014 17:46:14 post_install|File:/opt/cisco/install/bin/post_install:580, Function: handle_refresh_upgrade_failure(), Refresh upgrade failed. Trying to reboot to currently active version.|<LVL::Error>
05/23/2014 17:47:19 hardware_check.sh|Initializing hardware library on boot|<LVL::Info>
05/23/2014 17:47:19 ServerApiManager|In main with args -|initialize|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<LVL::Debug>
05/23/2014 17:47:19 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<LVL::Debug>
05/23/2014 17:47:19 ServerApiManager|In main with args -|initHardwareLibrary|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<LVL::Debug>
05/23/2014 17:47:19 ServerApiManager|Sam_reset being called|
I think it is similar to this other case: https://supportforums.cisco.com/discussion/12181161/cucm-vm-715-912-migration-error#comment-9719721
Can anyone help me with this? I am stuck on the migration.
Thanks!!
Héctor
Just for the record. I found the solution to my problem. Checking more logs I read this:
The installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
"/usr/local/cm/script/cm-dbl-ontape_backup-install RU PostInstall 9.1.2.11900-12 7.1.5.30000-1 /usr/local/cm/ /common/component/database /common/log/install/capture.txt " terminated. Exceeded max time (240)
The system will now halt.
So I accessed the Dissaster Recovery Section on CUCM and deleted the tape backup device that was configured there. After deleting it the upgrade went well.
Hi ,
thanks for sharing .
How did this Tape option strike you?
regds,
aman
