Blade failure recovery
delahais
I have associate a SP to a blade.
If the physcial blade failed, could I configurate the SP in order that automatically the SP should be  associated with another free blade ?
If YES, how I have to configurate the SP or SP template ?
Thx for your feedback
Best regards
Nicolas.
Keny Perez
Level 8
Level 8
Hi Nicolas,
I would give you a big answer to complicate the escenario, but Robert Burns answered this same question (unles I misunderstood you) a few days back, see this:
https://supportforums.cisco.com/message/4032942#4032942
The logic he explains is the reason why this is not done in UCSM.
I hope this helps with your question.
-Kenny
Keny Perez
Level 8
Level 8
Hi Nicolas,
-Kenny
Thx Keny for the url.
-Nicolas
Sure Nicolas, my pleasure.
-Kenny
