Blade move procedure
Andreas Linde
What is the recommended process for moving a provisioned blade (B230 M1) to a new set of FI/Chassi?
The new platform has a service profile template created and a B230 M4 blade already provisioned.
Would the first step be to decommission the blade i the old FI? Then what? Move to the new chassi, let it be discovered and then apply the same template as for the M4 blade?
Cheers!
Keny Perez
Level 8
Level 8
It would be:
-Disassociate the Service Profile  (SP)
-Decommission the blade
-Remove the blade
-Install it in the new chassis and let the system discover it
-Assign a new SP
Be careful your system has the proper firmware to support the server and the OS. This will help you out: http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Rate if helpful.
-Kenny
Keny Perez
Level 8
Level 8
It would be:
-Remove the blade
-Assign a new SP
Rate if helpful.
-Kenny
