C210 M2 Standalone and vSphere 5.5
Gregg Hughes
Good morning, all!
I'm working on upgrading the vSphere 4.1 currently running on my C210 rackmount servers to vSphere 5.5.  I found a document that showed that the server would work with vSphere 5.5 with the 1.4.3u software container.  However, when I rechecked my steps, the current interop matrix shows only vSphere 5.0 and 5.0U1 listed.  In my experience there's rarely been a retraction of compatibility on any OS interoperability.
Has anyone had good/bad experiences running vSphere 5.5 on these C210 servers they would share?  These will help us work out likely scenarios and traps to avoid in our rollout.
Thanks to all for looking!
G
Gregg Hughes
A little more information - the HCL that showed vSphere 5.5 is named r_hcl_C_rel1-54-1.pdf.
Thanks!
This HCL can help you as well and it is more user friendly:
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Note: I still recommend to always compare it against the .pdf version.
-Kenny
