C220M3 RAID Battery
When ordering a replacement RAID battery for a C220 M3 with a LSI MegaRAID SAS 9266-8i do you get the
UCS-RAID-CV-SC (Supercap)
or
UCS-RAID-BBU (BBU)
Battery type on CIMC is reported as iBBU09
This bug says to use the UCS-RAID-CV-SC but just wanted to confirm.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq91142/?rfs=iqvred
Thanks!
Wes Austin
You can order either one. Probably go with the supercap as outlined in the workaround from the defect you mentioned.
Wes Austin
Sounds good, thanks.
francisjqy
hello bro same issue but is this really the compatible one when ive login it is having 9volts dc rating but thisnsuper cap is 13.5volts pls advice if this really compatibke this supercap
