12-11-2014
01:23 PM
- last edited on
03-25-2019
01:39 PM
by
ciscomoderator
I did a manual firmware upgrade the other night. However under the Auto Install tab, it shows an install in progress. I never started an auto install, so I'm not sure why it even thinks that. It doesn't appear like it's even going anywhere. It's just sitting there at Waiting for UCSM Activate to complete.
Is there a way to end it? or stop it?
03-18-2015 12:06 PM
Did you check if your firmware really did not get updated? I have seen the FSM getting stuck when the firmware upgrade was really successful so all you have to do is re-run auto install with the already running version and the FSM completes to 100%.
Let me know,
-Kenny
01-27-2015 08:06 AM
Try to force it as I explained it here:
https://supportforums.cisco.com/discussion/11980776/upgrade-ucs-213a-stuck
This is the bug https://tools.cisco.com/bugsearch/bug/CSCug77812 but the explanation is here
https://tools.cisco.com/bugsearch/bug/CSCuf03650
If this helps, please rate it,
-Kenny
09-04-2018 11:23 PM
I just had this problem and figured it out. On the top, there is a pending activities flashing, the FI needs to reboot, but needs your permission to do it. You have to go to pending activities, and hit ok, reboot the FI. Then it will continue the upgrade.
