CIMC Secure Connection Failed in Firefox 27.0.1 works in IE 8.0
Jason Aarons
Level 6
Level 6
CIMC 1.5.4 on C260M2;
CIMC https to page;
SSL received a malformed Server Key Exchange handshake message. (Error code: ssl_error_rx_malformed_server_key_exch)
2 Accepted Solutions
marayson
Found a workaround:
Workaround is to change the max TLS version in Firefox. Go to about:config and
search for ‘tls’. Change ‘3’ to ‘2’ and restart.
Hello Jason,
We are currently investigating the issue via
CSCun04933
CIMC Web GUI not working after updating Firefox to 27.0
Padma
6 Replies 6
marayson
Found a workaround:
Hello Jason,
CSCun04933
Padma
This worked for me - thank you.
It helped , Thank you
Aswini Parida
Go to Location bar  in Mozilla firefox and type about:config and then search for security.tls.version.max,modify the value to 2 from 3.
close the all the mozilla firefox tabs to make the changes effect and reopen the CIMC IP. it should open without any issues.
ahochau_2
I'm getting the same error with firefox 28 and also firefox 29.  I checked the setting that default was already at 3, moved it to 4 and there was no change.  Wouldn't be so annoying except for the fact IE 11 seems to break other things, such as the ability to update the firmware.  Will have to track down an XP machine......
