Cisco UCE-140S Won't auto turn on?
dastrix80
Hi All, running CICM 3.2 , same software as another module I've got (the 140D). This 140S refuses to auto power on when I reboot the Ubuntu Linux server. If I open the KVM, i see the green screen and it shows the power off.
How can I set it to auto power on? Ive changed the gui option to power on but it fails.
Something im doing is wrong!
Cheers
Kris
Kirk J
Greetings.
Assuming you have set the Power restore Policy (Compute, power policies) to power the server on if power loss.
Also, you might want to try booting (via vKVM ISO) a live ubunto or centos Image, and doing a reboot.
This will help determine if your installed ubuntu OS has some sort of ACPI/power control issue, or if it is indeed some sort of hardware/bios issue.
Kirk...
Kirk J
Greetings.
Kirk...
Hello Kirk
yes I do have the policy defined.
Interesting, OK, ill look into that a bit more, thank you!
dastrix80
Looks like ive solved it. I black listed the Intel AMT/MEI driver from loading, using sudo shutdown -r seems to reboot the server correctly :)
