10-30-2016 10:39 PM - edited 03-01-2019 12:56 PM
Is the Cisco UCS B200 M4 blade server compatible with 2100 FEX inside a Cisco UCS 5108 Chassis & Cisco UCS 6100 Fabric Interconnect?
Solved! Go to Solution.
10-31-2016 12:40 AM
The interop tool clearly says for the B200-M4:
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Note 14: The 2104XP fabric extender is not compatible when the 1240 and 1280 or 1240 and VIC Port Expander are combined on the same blade. Applies to B22 M3 and B200 M3 as well as B420 with 1240 and adapter slot 2 populated
or for the VIC 1340
Note 38: 6100 Series Fabric Interconnects and 2100 Series Fabric Extender is not supported
10-31-2016 12:40 AM
or for the VIC 1340
10-31-2016 01:03 AM
Thank you.
