CIsco UCS FI ( 2.23e) License issue
I have UCS system running firmware version 2.2(3e) and after applying additional four port licenses for each Fabric Interconnect, I got a warning message that fabric-interconnect entered grace period.
We have these warning although we are not over provisioning any ports ( e.g Absolute quantity = used quantity ). // please check the attached screenshot.
I want to check if anyone had this issue before and if it is bug or not.
Mohammad
Marcin Latosiewicz
https://tools.cisco.com/bugsearch/bug/CSCui19338/?reffering_site=dumpcr
possibly?
Marcin Latosiewicz
possibly?
Thanks Marcin ... I applied one of the workaround for this bug ( reloading FIs ) and issue has been resolved. However, current firmware version is not listed in the ones hitting this bug.
Thanks again.
For future reference:
If your firmware revision is below the fixed release you can be affected by the bug.
Justin
