Cisco USC-C210-M2 will only detect esxi flash drive install if I boot
lukutu
I'm about to go insane here. I've installed esxi 6.7u1 on my c210-m2, however the bios only detects the flash drive as bootable if I boot the installer ISO first and reboot. I've tried both legacy & uefi bios and no dice, doesn't appear in the BIOS as a bootable device unless I boot the installer first. BIOS/CIMC/firmware all updated.
Kirk J
What storage controller are you using to connect the supported SSD to?
https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/spec_sheet_c17-644230.pdf
Kirk...
Christian210876
Hello Lukutu,
M2 servers are quite old. look at the EOS and Hardware Compliance List (HCL)
As I see it it is only supporting up to version 5.5 not even any updates and not even version 6 of ESXi.
