07-24-2020 06:01 AM
Hi All,
I see some obsolete entries from as far as 1 month back in the Recovery and Maintenance tab of the HX Connect and was wondering if there is a way to clear them?
07-26-2020 08:02 AM
Try running the following on all nodes (as root):
service hxmanager restart
service nginx restart
service tomcat8 restart
This will not impact datastores/VMs
You will probably need to log back into hx connect gui.
Kirk...
08-06-2020 07:25 PM
Hi Kirk, I did these commands on all the storage controller VMs of all 8 nodes but still seeing the hanging events even with re-login to HX Connect.
08-11-2020 05:53 AM - edited 08-11-2020 06:13 AM
Greetings.
Confirmed to be an issue described at: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs40350
For now, you will need a tac case, to help get these cleared out.
Can you confirm what HX version you are running?
Kirk...
08-11-2020 06:16 AM
01-15-2021 10:12 AM
Hi Owk,
I'm having the same issue, what is the solution?
MC
