Fabric Interconnect inventory is not complete
brandon.keep
I have recently started seeing this message within our UCS enviorment.
XXXXXX00-A# show fault
Severity  Code     Last Transition Time     ID       Description
Major     F0885    2015-11-01T20:48:03.980   2489810 Fabric Interconnect B inventory is not complete card-inventory,eth-pc-inventory,eth-port-inventory,fc-pc-inventory,fc-port-inventory,mgmt-port-inventory,remote-eth-port-inventory,switch-fru,switch-inventory
I was wondering if anyone has any ideas on how to clear this error or where to start looking for clues as to its origin? Searching Google has not yeilded anything fruitful. I do not see any issues in operations that I can tell as it seems everything is working okay on both FI's. Is there maybe a way to force another inventory check or something like it?
Thanks for any information.
Brandon
17 Replies 17
All it says is 'Password:'
Do you have to use the actual 'admin' account for some reason?  Not a normal account with admin role, which I use for everything else?  Our 'admin' account has a 30 char random password, and it seems you can't paste easily here...  :)
I thought I'd done this before, but guess not unless it was before 2.2(3c) this showed up needed special access...
In later versions of UCSM, you must execute pmon stop/start from the admin account and input the admin credentials when you execute the command.
-Wes
Ugh....  Thanks much for the update, that sure wasn't mentioned...  'An admin account' is NOT 'the admin' account.  :)
I'll give that a try, appreciate the quick feedback!
