Healthwarning Networkers with ESXi 6.0 and ESX 6.0 U1
Walter Dey
Hi networking guys !
Be aware of the following nasty feature. Sorry for any duplicates !
This issue is resolved in ESXi 6.0 Update 1a, available at VMware Downloads. For more information, see the VMware ESXi 6.0 Update 1a Release Notes.
Walter.
ESXi 6.0 network connectivity is lost with NETDEV WATCHDOG timeouts in the vmkernel.log (2124669)
After upgrading to or installing ESXi 6.0.x and ESXi 6.0 Update 1, you may experience these symptoms:
  • ESXi 6.0 host network connectivity is lost randomly
  • ESXi enters into a non-responding state and becomes unmanageable until reboot
  • Network connectivity does not return until the ESXi 6.0 host is rebooted
  • After rebooting, the issue is temporarily resolved for a period of time, but occurs again after a random interval unless the workaround (script) is implemented
  • In the /var/log/vmkernel.log file, there is evidence of transmit timeouts. This is often logged by the NETDEV WATCHDOG service in ESXi. You may see entries similar to:
    YYYY-MM-DDT21:35:34.007Z cpu0:33245)WARNING: LinNet: netdev_watchdog:3678: NETDEV WATCHDOG: vmnic0: transmit timed out
    YYYY-MM-DDT21:35:34.007Z cpu0:33245)WARNING: at vmkdrivers/src_92/vmklinux_92/vmware/linux_net.c:3707/netdev_watchdog() (inside vmklinux)
    Note: The preceding log excerpts are only examples. Date, time, and environmental variables may vary depending on your environment.
  • This issue can impact multiple network adapter types across multiple hardware vendors The exact logging that occurs during a transmit timeout may vary from card to card.
Note: This issue does not affect ESXi 5.5 and earlier releases, only ESXi 6.0 is affected.
Keny Perez
Level 8
Level 8
Great info, thanks for that Walter!
-Kenny
