Help me!!! How do i configure the memory on UCS C460 M2?
Insung Choi
Level 4
Level 4
Hello!
I need...... configuration best practice guide for UCS C460 M2.
1. what is the memory configuration of max memory clock?
  ex) 16GB pair kit, 32DIMM slots -> Total size ; 512GB, clock speed : 1066Mhz?
2. When install of all memory,  what's the memory speed and total size?
  ex) 16GB pair kit, 64 DIMM slots -> Total size : 1TB, clock speed : 1066Mhz or 800Mhz???
http://www.cisco.com/en/US/products/ps10493/prod_models_comparison.html
compare product list : UCS C460 M2 - Total memory size 2TB?? true?
spec sheet : UCS C460 M2 - Total memory size 1TB.
Help me please~~!!!
Thanks for you.
micturne
Level 4
Level 4
Hello Insung,
I will make sure your questions get into the right hands.  We should have an answer for you by next week.
Thanks for posing:).
Mike
Hello Michael.
Cisco engineers of Korea offered me the technical documents. but, I will wait your answer.
Best regards,
Insung.
admin11111
Level 4
Level 4
Hi Insung,
For either 32x or 64x 16GB DIMMs, the max operating speed is 1066MHz on the C460 M2.  You can find more information here:
http://savtg.cisco.com/index.php/component/attachments/download_unsecure?attachmentid=1608
Also, C460 M2 supports up to 2TB of memory with 32GB DIMMs.
Judy
