How to change svs connection remote ip address - vCenter was reloctated
nick_adair
We just finished relocating our vCenter from one subnet to another, the IP address changed and now we can't add any vmware port groups in the vNetwork Distributed Switch.
When we tried to add the port-profile the warning was "Warning: Operation succeeded locally but update failed on vCenter server. Please check if you are connected to vCenter Server."  We checked the configuration on the Nexus 1010V and found the culprit, the svs connection back to the vCenter had the old remote ip address.
What is the preferred method to change it without wiping out the config?
Thanks in advance.
chrisb2
The way to do this is the following:
n1000v(config)# svs connection vcenter
n1000v(config-svs-conn)# no connect
n1000v(config-svs-conn)# remote ip address 1.1.1.1
n1000v(config-svs-conn)# connect
Basically disable the connection, change the IP, and then re-enable the connection.
chrisb2
nick_adair
Worked like a champ.  I was worried about losing my config and having to rebuild a bunch of stuff.
Thanks again!!
