Management Interface is down
ajaypatil1
We have the clustered ucs domain and its showing the management interface is down.below checks i have done.
Able to ping the gateway from both Mgmt Interface A and B.
There is no packet loss between the Management interface and switch interface where FI A is connected.
5 Replies 5
Saurabh Kothari
existing CSC forums on the issue:
https://supportforums.cisco.com/document/11936031/ucs-getting-error-message-management-interface-fabric-interconnect-down
https://supportforums.cisco.com/discussion/11895856/strange-error-message
Keny Perez
Level 8
Level 8
Could you please tell us if you mean that "mgmt0" shows as down?  If not, please paste here the output for the error message or screenshot of the error.
-Kenny
ajaypatil1
The output the same below.but we are found this interface state flapping.
FI-BAL16-1-B(local-mgmt)# show mgmt-ip-debug
Ifconfig Info
eth0 Link encap:Ethernet HWaddr 00:2A:6A:15:E9:20
inet addr:192.168.246.62 Bcast:192.168.246.255 Mask:255.255.254.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:571856 errors:0 dropped:0 overruns:0 frame:0
TX packets:223429 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:44835327 (42.7 MiB) TX bytes:18630272 (17.7 MiB)
FI-BAL16-1-A# sho cluster extended-state
Cluster Id: 0x63470844da5411e2-0x9d4b002a6a1d63e4
Start time: Wed Jul 31 13:34:28 2013
Last election time: Wed Jul 31 13:39:57 2013
A: UP, PRIMARY
B: UP, SUBORDINATE
A: memb state UP, lead state PRIMARY, mgmt services state: UP
B: memb state UP, lead state SUBORDINATE, mgmt services state: UP
heartbeat state PRIMARY_OK
INTERNAL NETWORK INTERFACES:
eth1, UP
eth2, UP
HA READY
Detailed state of the device selected for HA storage:
Chassis 1, serial: FOX1712HD7U, state: active
FI-BAL16-1-A#
and below is monitoring policy configured.
set mgmt-if-mon-policy admin-state enabled
     set mgmt-if-mon-policy monitor-mechanism ping-gateway
     set mgmt-if-mon-policy ping-deadline 15
     set mgmt-if-mon-policy ping-requests 3
     set mgmt-if-mon-policy poll-interval 90
So you are saying that when you run the command "FI-BAL16-1-B(local-mgmt)# show mgmt-ip-debug", sometimes it does not show as running?
When you say it is flapping, does it mean that UCSM becomes unreachable for some time and then comes back up?
Please provide as much details about the issue as you can.
-Kenny
dvallyon01
As per link below, this is the setting found in the "Management Interfaces Monitoring Policy" The default setting is it will try and ping the default gateway. If it cant ping the gateway it considers itself as down. Even if you are clearly connecting to it (possibly locally). This can either be disabled or change to another option such as "MII status or Ping ARP Targets for Ipv4 and Ipv6"
or of course make a gateway available.
Ive had this a few times when setting up new FlexPod environments which in some cases the GW is yet to be configured.
Hope this helps
Daren
