Management port on fabric interconnect question
Jcard1971
I'm using the same pool of of IP addresses for my FI and KVM pool.
I need to make sure that my management port on each FI is connected to a switch that is also accessible in the same range\subnet, correct?
After setting everything up, I'm currently unable to get to my VIP.
Robert Burns
Correct.  Ensure the subnet masks are correct, and the gateway is reachable.  If you can "ping" from outside to each FI's management IP, there's no reason you shouldn't be able to reach the VIP.  Obivously the VIP address must be in the same subnet & VLAN as the management IPs, and not be used elsewhere in your environment.
Robert
