Mix 2104XP and 2204XP
I have a chassis with one 2104XP module and B200M2 servers
Can I put a 2204XP module and B200M3 servers to this chassis?
Thank in advance.
3 Accepted Solutions
abbharga
Level 4
Level 4
Hi Hoang,
Are you looking at this mix of IOM as part of the migration or normal operations?
You will be able to install the two IOM in the mix (please note: you would need the UCSM / FI running the minimum supported code for 2204 XP), however i would suggest you not to run them in the mix for long since this is not a supported and tested topology and you might face unknown issues. depending upon the service profile configuration you might even have profile association issues. Both the IOMs exchange are aware of each other and in case either of them is not able to collect the desired information we could see issues there as well.
Installing the B200 M3 blade with an IOM should not be an issues (again with the minium required software version)
some documents to help you:
release note: for minimum supported versions;
http://www.cisco.com/en/US/docs/unified_computing/ucs/release/notes/OL_25363.html#wp229535
B200 M3 spec sheet:
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/B200M3_SpecSheet.pdf
(you may want to look at "Network Connectivity" section for the possible connectivity options with a given IOM)
Thanks!
./abhinav
Here is what you need to do:
1) First configure the new FI as another standalone deivce,
2) Upgrade the firmware to match the current one i.e. 2.0.2q
3) Erase the config on the new FI and get it to the initial config mode again
4) Enable the cluster on the current standalone:
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/cli/config/guide/1.3.1/CLI_Config_Guide_1_3_1_chapter4.html#task_9858FADCDF6E4D2B852118CCEEBAA3DC
5) Connect the ports on the new FI, mgmt and l1&l2
6) complete the initial config of the new FI, you can choose it to connect to an exiting cluster.
I am not sure if i got the last part correct, but an IOM can connect only to one FI. In your case, you need not change the connections between the current FI and the IOM on the chassis. You can connect the other IOM to the new FI. You will have to configure the ports on the new FI as the server and uplink ports and any other ports as required.
./abhinav
8 Replies 8
abbharga
Level 4
Level 4
Hi Hoang,
B200 M3 spec sheet:
Thanks!
./abhinav
Thank abhinav.
So can I replace all 2104XP modules with 2204XP modules?
I'm using B200M2 with VIC M81KR, and ucsm 2.0(2q)
Thank Abhinav
I have a fabric interconnect 6248UP, run 2.0(2q) software in standalone mode.
I buy a new FI 6248UP for cluster configuration.
So do I need to upgrade firmware to match each other before?
Cluster configuration requires symmetrical connection topology, but can I connect a chassis with only one IOM to a cluster FI (of course, no redundancy)?
./abhinav
@Abhinav
I followed your instructions to upgrade ucsm and all firmware to ver 2.0(4a), and all works well
Thank you so much for your help.
Do you have any document about all parameters of hardware components in ucsm?
I add a PSU into an existing chassis. It works well, but in ucsm, column "thermal", "performance" and "voltage", it shows N/a status. And in cpu, column "operability" show N/a status.
I think it's not a problem, but I need to explain to my boss :|. If you have any document, plz share with me.
Thank in advance.
Hi Hoang,
can you help me with the screen shots for both of these status?
This will make it easy for me to check and update you.
./Abhinav
Hi Abhinav,
These are screenshots of fans, psus and cpus.
Thank in advance
