NPV mode en target / initiaor
a.auvinet
Bonjour,
  • I have 2 fabric SAN with  brocade
  • I have 2 nexus 5548 with  Npv mode enable connected to brocade
  • More servers are connected to nexus in FcOE / 10g/b etherne
All works fine.
Today, stokage system is connected in natif  FC on Brocade
All works fine.
I would like to connect a Netapp system storage (Target ) on Nexus Nexus 5548, which are in NPV mode .
I don't find if it's possible to do this.
Cdlt,
Walter Dey
Salue !
A N5k in NPV mode is a HBA concentrator, not doing any FC/FCoE switching; which is done by your Brocade (Cisco calls this NPIV mode).
see http://www.dasblinkenlichten.com/npv-and-npiv/
No, this is not possible; you have to connect your NetApp to Brocade as well.
Walter.
Hi Walter,
Ok, thanks you.
I have a other question :
My nexus are in NPV mode
- I would like enable the feature npiv, can I enable npiv  on Nexus 5548 when npv is already activate ??
    > It's for esx
- If yes, when i enable npiv on nexus 5548, is  the nexus reload ?
Cdlt,
NO !
NPV and NPIV are complimentary technologies. You can only have one or the other !
In most cases, you would have enable NPV mode on your edge/access switch, which could be something like a MDS 91xx.
Enabling of NPV mode is disruptive (Reboot)
Then to take advantage of NPV mode on the 91xx switch, you would enable NPIV on your core director (MDS 9506/9509/9513).
Enabling NPIV on the 95xx director is not disruptive (no reboot), enabling NPV mode on the 91xx requires a reboot of the 91xx.
