Odd power supply fault callhome emails on Cisco 2232 FEXs?
We recently enabled smtp callhome for our ucs pod a few days ago. Since then, we've received more than a dozen email bursts about power supply failures in each of the four Cisco Nexus 2232TP FEXs in our pod. In each case, we get a "Recovered" email within a minute or two, and we're not seeing power supply failure emails for any other devices within the UCS pod.
Here's a sample email burst from this morning, showing the subject lines within my email inbox:
System Notification from atl01-ucsf01a-A - environment:major - 2012-10-23 06:01:27 GMT-00:00 Recovered : Power supply 2 in fex 6 operability: inoperable
System Notification from atl01-ucsf01a-A - environment:major - 2012-10-23 06:01:27 GMT-00:00 Recovered : Power supply 2 in fex 6 power: error
System Notification from atl01-ucsf01a-A - environment:major - 2012-10-23 06:00:58 GMT-00:00 Power supply 2 in fex 6 operability: inoperable
System Notification from atl01-ucsf01a-A - environment:major - 2012-10-23 06:00:58 GMT-00:00 Power supply 2 in fex 6 power: error
If we were seeing this from just one fex, I'd suspect a hardware issue. If any of the other UCS devices (rackmount/blade servers, fabric interconnects, etc) reported similar issues, I'd suspect a power feed problem within the DC.
But this has me baffled. If it helps, the UCS pod is running firmware 2.0.3c
Cheers,
Paul
Thanks Paul,
It is known ( cosmetic ) issue with power supply model.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtz84683
The above is resolved in recent version of Nexus 5K switch software. New defect to port the fix to UCSM has been submitted today
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCuc87547
It will take a while to get published on web site.
Even though they are cosmetic, I would suggest you open a TAC SR with UCSM, FEX tech support and above bug IDs so that we can track the resolution.
Padma
padramas
Hello Paul,
can you please share following output
scope fex
show psu detail
connect nxos
show logging | egrep -i 'power|gpio'
Padma
Padma,
Thanks for the reply. I've attached the requested information, and let me know if I can provide any additional details.
Cheers,
Paul
Thanks Paul,
Padma
Thanks for the reply, and it's a bit of a relief that this is a known issue. I'll open a TAC SR as you suggest.
Cheers,
Paul
