powershell command to get serial numbers and model
Dragomir
can someone help on this?
need to get the model # and serial on my blade servers
Walter Dey
If you know how to do it with UCSM, it's easy
First install the UCS PowerTools and Connect to your UCS with the same user you connect to the UCS Manager.
After that run the cmdlet:
And issue the UCS Manager command to show serial number
I was able to get this workimng
get-ucsserver | select UCS,DN,Model,Serial
how do I get the service profile to ucsserver mapping?
You select the proper service profile, and if is associated, you will see which blade it is.
You have to enter this sequence of UCSM commands, and finally get the sequence of necessary powershell commands
