Powertools for UCS scripts fan norxack stats
dbrownad1
Hello all,
Does anyone have an idea about how to get norxack stats from the fans on multiple IOMs with powertools?
Jarret Gonzales
I am unsure of how to review norxack stats using powertools, but I can provide you with an alternate solution.
1) Download Tech Support files using the guide below. Be sure you are selecting the appropriate Chassis.
- http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/115023-visg-tsfiles-00.html
2) Once downloaded, dig into the directory to locate the IOMs. They will have a directory listed similar to: IOCard1 or IOCard2
3) Navigate through the IOCard directory to CMC > LOG and locate 'i2c.log'
4) Within this file you can search 'norxack' to find the counters for different components within your environment. Example below:
segment 1 chassis
norxack 58
pca9541seterr 27
wait_gt_deadline 9794
segment 2 blade
segment 3 fan
wait_gt_deadline 2
segment 4 psu
wait_gt_deadline 1
Hope this helps someone!
- Jarret Gonzales
Correct Jarret, or you can also do it through the CLI with the blow commands:
#connect local A|B  (choose A or B to check the IOM attached to that fabric Interconnect)
#connect IOM #   >>> # will be the chassis #, no need to specify the IOM as only 1 IOM will be connected to the FI specified in the prev command
#show platform soft cmcctrl showi2c
-Kenny
