Resetting FSM for Port Profiles
terran0925
I'm currently trying to fix the faults we have in one of our UCS environments and one of them is the FSM tab for the VM --> All
--> VMware --> Port Profiles.
Someone tried to configure a port profile here and the progress status has been stuck for months.  The Port Profiles currently aren't being used so I already deleted all of the port profiles but the FSM tab is still stuck.  I've been in the CLI as well and could not find a way to reset it.  Any ideas?
Thanks.
5 Replies 5
Manish Tandon
Terence
This functionality of deletion of pending tasks should exist and doable via either the GUI or the CLI.
There should be a "Deletion Tasks" tab in VM/VMware tab in the GUI and pending tasks can be deleted.
In the CLI, scope system, vm-mgmt, vmware and then you can scope to a pending-deletion task which you do a show detail for or a "delete pending-deletion "
--Manish
Thanks Manish.  I've actually looked in that tab/window and gone into CLI but can't seem to find any tasks listed.  See the screenshots
I've included.
Terence -
Interesting; it looks like the FSM is complaining that the port-profile name was too long, though it doesn't even allow you to click "OK" if you've entered more than the maximum number of characters for the name.  If you create a new test port-profile, does the status of the FSM change accordingly?
Jen
Great tip Jen!  I deleted all the ports yesterday to see if it'll clear it with no luck but I just created a "test port" and that got displayed properly and seemingly removed the stuck status.
Terence, that's great!
