System Halted after Cisco UCS C225 M6 Upgrade
betaaaa
Hello all,
Recently we upgrade our UCS C225 M6 firmware from shipped Release 4.3(4.242038) to Release 4.3(5.250030) by using HUU under this guidance from Cisco
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/lomug/4-3/b_cisco-host-upgrade-utility-user-guide-4-3/m_upgrading-the-firmware.html
all steps completed by just only Upgrading CIMC, BIOS and CISCO UCS VIC 1455.. all green checked and no error notification.. and then the reload perform automatically and at the end of the reload step, we got notification that mention  : "reboot : System halted"
*we want to run Nexus Dashboard on our UCS
the KVM console couldn't received any input like before we upgrade the firmware, like this :
before upgrade:
after upgrade:
we even try to rollback the upgrade using GUI on CIMC, and it's worked again like before the upgrade performed.. with several steps we've done below :
- upgrade CIMC from 4.34 to 4.35 vKVM mapped DVD HUU > system halted
- upgrade BIOS from 4.34 to 4.35 vKVM mapped DVD HUU > system halted
- Rollback one by one CIMC, BIOS dan Network Card to 4.34 using CIMC GUI> running well
- Upgrade CIMC, BIOS dan Network Card from 4.34 to 4.35 vKVM mapped DVD HUU> system halted
- Unplug power / power off UCS > system halted
- Reload CIMC version 4.35 > system halted
- Reset system from KVM on version 4.35 > system halted
- Rollback BIOS to 4.34 using CIMC GUI > system halted
- Upgrade BIOS to 4.35 using Bootable Flashdisk RUFUS > system halted
we just wondering, is that the step we went through are wrong? or we missing something else ?
hopefully could have some inspiration from all you guys
cheers
Yes, I would just downgrade to the 4.3.4 version until a fixed release is available.
Wes Austin
Sounds like you are running into one of these defects. If you are still having issues after attempting the workaround, it may be best to open a TAC case and we can review and provide next steps accordingly.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwo74485
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwo61222
is that mean, for now we need to perform downgrade simultaneously to the previous version 4.34 by using HUU by check all part (BIOS, CIMC, VIC) downgraded together ?
okey thank you, we did the downgrade to 4.3.4 version and everything run well..
