12-19-2024 04:58 PM
I am having a cisco flexstorage controller inserted in my b200 m4 server, however any drive i have put into the slot does not appear to be detected. they are SATA drive, are these not working?
12-20-2024 05:27 AM
Are the drives one of the models from the specsheet at: https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/b200m4-specsheet.pdf ?
That SAS controller does list a number of supported SAS and SATA model drives.
Kirk...
12-20-2024 04:15 PM
no, it is a SATA seagate 250gb hdd i found
12-20-2024 11:44 PM
It seems that the controllers OEM firmware has been customized to filter out drives that are running Cisco customized firmware , probably by using the OEM PN#/Model# identifier strings.
If you only need 250GB, of course you could just connect a $30 USB3 thumb drive. >:}
I checked on EBAY. I found you can get compatible 248GB drives for about $130, which is less than the going-price for dinner in Paris France these days. I used PNs# from the PDF I searched for:
UCS-SD240G0KS2-EV
UCS-SD240GBKS4-EV
UCS-SD240G0KS2-EV
UCS-SD240GBKS4-EV
12-21-2024 12:01 AM
I did try using a USB, however it seems that there are only USB1 speeds available on the internal USB slot, which caused great regret when using windows to go.
I am thinking that a HD300G10K12G drive should work well, and while it is spinning rust, it goes for around 16$ on ebay
12-21-2024 12:41 AM
I suppose this is the downside to Cisco UCS: No conceivable way to have a low cost lab setup. The good news is that most Cisco UCS roles pay $150k+, especially if you're acquainted with ACI, VXLAN, and VSAN (or HyperFlex), you can find yourself invoicing over $800/day C2C/1099.
Except in France. They can only afford Dell. Gah.
12-27-2024 04:29 PM - edited 12-27-2024 04:31 PM
01-03-2025 09:59 AM
Machine Check ending with "00B0" means:
Memory Controller Errors / Channel Number 0
Remove/reseat DIMMs in the first memory channel.
Could also (rarely) be a faulty CPU or poor CPU seating.
I'd do some isolation to help determine the faulty part (or simply seating):
Depending on what happens on each step would help determine if this is simply seating or a bad DIMM or a bad slot (could be motherboard or could be CPU or could be CPU seating.)
