To enable HTTPS option for UCSM
Subramanien R
Hi Friends,
  In my environment, found HTTPS options is disable in communication mgmt tab. I would like to enable HTTPS to access the Fabric interconnect. how ever my concern is, If i enable the option, will it requries any service / FI reboot or will it leads to any outage in the environment..
Thanks in Advance !!
Wes Austin
This is only impacting the control plane so it should not impact any data traffic. Conduct the change during off-hours to be safe. It does not require a reboot or downtime.
Thanks for your Suggesstion Wesley Austin..
