UCS 5108 chassis
Tech Support
can I mix the B480 M5 with B200 M3 in the same 5108 chassis
mojafri
Yes you can..Generally there is no restriction on having mixed blade type in chassis.
MJ
Stephan Cook
You'll want to make sure the versions of firmware and UCSM support both blades. Other than that no, there wouldn't be an issue.
