UCS C210 M2 Second NIC interface
Leonardo Santana
How can i activate the second virtual interface of UCS C210 M2?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Walter Dey
Only a single Cisco UCS P81E Virtual Interface Card/ 2-port 10 Gb card may be installed and it must be installed in slot 1- slot 2. Note, however, that if the server is running UCSM, only slot 1 supported for the VIC card.
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/spec_sheet_c17-644230.pdf
I have two interfaces.
This interfaces can i use one for a DMZ purpose?
Leonardo Santana
Leonardo Santana
Leonardo,
Please visit the following links:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C210M1/install/C210M1/replace.html#wp1135896
http://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/data_sheet_c78-558230.html
Product Overview
A Cisco innovation, the Cisco UCS P81E Virtual Interface Card is a virtualization-optimized Fibre Channel over Ethernet (FCoE) PCI Express (PCIe) 2.0 x8 10-Gbps adapter designed for use with Cisco UCS C-Series Rack-Mount Servers. The virtual interface card is a dual-port 10 Gigabit Ethernet PCIe adapter that can support up to 128 PCIe standards-compliant virtual interfaces, which can be dynamically configured so that both their interface type (network interface card [NIC] or host bus adapter [HBA]) and identity (MAC address and worldwide name [WWN]) are established using just-in-time provisioning. In addition, the Cisco UCS P81E can support network interface virtualization and Cisco VM-FEX technology.
