UCS mini + 4 switches, no VLANs
Alex S.
Hi all,
I have a UCS mini with 6324 I/O modules with 5x B200 m3 blades, each running ESXi 6.0.
I want to uplink the UCS mini with four cables to four separate switches for traffic, and I wish for each b200 ESXi host to see four separate vmincs, one on each network. The switches have no VLANs, but are running DHCP. I wish to get DHCP from each adapter.
How should I go about mapping the vNICs?  LAN Pin groups?
Hi Alex,
That is correct. You can also implement Layer 2 disjoint explained in the guide below for more secure access.
http://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/unified-computing/white_paper_c11-692008.html
Hope this helps.
Qiese Dides
Alex S.
I think I found my answer in this document:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/gui/config/guide/3-0/b_UCSM_GUI_User_Guide_3_0/b_UCSM_GUI_User_Guide_3_0_chapter_010110.html
Looks like VLANs are required
Hi Alex,
Hope this helps.
Qiese Dides
