Upgrading firmware to 3.1 (1e).
hpacheco3621
I have a few B2000M3 servers that have firmware 2.0 (3c).  I would like to upgrade to 3.1 (1e).  Can I jump from firmware 2.0 (3c) straight to 3.1 (1e)?  Or do I have to go to 2.1, 2.2, 3.0, then 3.1?  Please advise.  Thank you.
Qiese Dides
Hi Hpacheco3621,
If you reference the guide below specifically Table 7 it will show you the Minimum Software Versions for Blade Servers. For the B200 M3 Server you can see which firmware versions you need for the specific Fabric Interconnect you are running. Under the link I uploaded a snippet of the section.
If these answered helped you please mark this post as a solution so others can find this information readily.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/CiscoUCSManager-RN-3-1.html
Qiese Dides
skarthic
I assume your UCS infrastructure is currently on 2.0/2.1?
Upgrade from 2.0.3 to 3.1.1 would need a two step upgrade from 2.0.3 -> 2.2 and 2.2 ->3.1.1e
So the steps are
1) Upgrade UCS infra to 2.2.x release
2) Upgrade blades to 2.2.x release
Procedure:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/upgrading/from2-0/to2-2/b_UpgradingCiscoUCSFrom2-0To2-2.html
3) Upgrade UCS infra to 3.1.1e
4) Upgrade blades to 3.1.1e or a suitable release
Procedure:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-manager/GUI-User-Guides/Firmware-Mgmt/3-1/b_UCSM_GUI_Firmware_Management_Guide_3_1/b_UCSM_GUI_Firmware_Management_Guide_3_1_chapter_01.html#concept_F4E8EB876BC949E2855327611B88B866
As mentioned in the link
"Before upgrading to Cisco UCS Manager Release 3.1, ensure that the existing infrastructure and server bundles are on a Cisco UCS Manager 2.2(x) release, or later releases.
Important:
Upgrading from infrastructure bundles earlier than Cisco UCS Manager Release 2.2(1a) is not supported."
Hope that helps
Thank you very much Skarthic.
