every time I re-acknlowledge a server or perform a host firmware update UCSM will disable the TPM in my C240-M3 Systems. In the BIOS policy the TPM is configured to be enabled.
When UCSM is able to disable the TPM, why isn't it able to enable it, or even better, keep the setting as it is?
Currently I have to open a KVM session, enter the BIOS and enable the TPM manually and there is no way to automate this process.
Kind regards,
Stephan
