Blade move procedure
Andreas Linde
Visitor
What is the recommended process for moving a provisioned blade (B230 M1) to a new set of FI/Chassi?
The new platform has a service profile template created and a B230 M4 blade already provisioned.
Would the first step be to decommission the blade i the old FI? Then what? Move to the new chassi, let it be discovered and then apply the same template as for the M4 blade?
Cheers!
Keny Perez
Level 11
Level 11
It would be:
-Disassociate the Service Profile  (SP)
-Decommission the blade
-Remove the blade
-Install it in the new chassis and let the system discover it
-Assign a new SP
Be careful your system has the proper firmware to support the server and the OS. This will help you out: http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Rate if helpful.
-Kenny
Keny Perez
Level 11
Level 11
It would be:
-Remove the blade
-Assign a new SP
Rate if helpful.
-Kenny
