06-17-2015 07:16 PM - edited 03-01-2019 12:14 PM
Is there something special with the internal SAS cable? LSI says I need SFF-8087 cable but doesn't appear its that simple.
Thanks!
06-18-2015 07:27 AM
What is the problem?
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C210M1/install/C210M1/replace.html
"The expander has two mini-SAS SFF-8087 cable connectors. One connector provides connection for up to 16 drives, and the second connector provides redundancy. "
How many disk do you have and how many do you want to support?
-Kenny
06-18-2015 07:40 AM
The LSI 8i supports connecting two SFF-8087 cables but appears a standard SFF-8087 to SFF-8087 cable doesn't work. I am not sure if Cisco has some proprietary pinout in the stock SAS cable before I keep troubleshooting while the second standard cable isn't working.
