GLC-T Connector in nexus 5548
smartboy2255
HI all,
    I am getting "SFP validation failed " error after inserting GLC-T connector in 5548 nexus switch.Is thre any seperate config required for GLC-T connector.
Ajith
23 Replies 23
David McFarland
Ajith,
Set the interface speed to 1000
interface ether x/y
speed 1000
Dave
Dave,
   I have done speed to 1G then I am getting error " link not connected" even I have connected the nnetwork cable.
Ajith
Leo Laohoo
It's GLC-T and not GLC-TX, right?
Yes it GLC-T , I have tried with 4 GLC-T connectors but all are getting same problem..
Ajith
If you have one (or more) working, swap it around.
I have done swapping with 4 connectors. This is new implementation. All four are getting same error
Are you saying that not one of your GLC-T works?
If this is so, what version is your IOS?
Yes I am getting all four same error. pls find the IOS version.
version 5.0(2)N2(1)
Switch that you use to connected with Nexus 5548 support Gigabit Ethernet ??
Why don't you test loop connect within 5548 to check port is up or not
As per datasheet nexus 5548 , switch will support GLC-T connector.
try this
unplug your GLC-T, configure/re-configure the speed to 1000.  Then, insert GLC-T.
richard.pugh
What version is the GLC-T? I had the same issue a while back and Cisco will on support GLC-T v.3
Prashanth Krishnappa
1gig capability was added to NX-OS 5.0(3)N(1)1 and later
jackychen.rlc
Ajith,
Have you solve this issue now?
