how delete internal port-channel with no members
In Internal LAN section, I have a port-channel with no members. When I try to delete it with GUI, I have an error "Port channel cannot be deleted". With CLI, I only can delete member, but I have no members.
Thanks for help
Stéphane
6 Replies 6
dfilenko
Most likely, this PO remained from having Chassis discovery policy set to port-channel (it's number is 1000 range usually) . You can set it back to individual links and then re-acknowledge the chassis. This will cause ~20 second connectivity disruption and should remove port channel.
Thank Dmitri for you answer.
I acknowledged the chassis with 2104XP modules and i still have the problem for 2 slots.
Check attachments
2104 does not support port-channels for connectivity.
What Link grouping preference is set to (under equipment -> policies-> global policies)?
Yes, this is why I don't understand the presence of port channel for the links of 2104.
The discovery policy of chassis is 2 links with no port channel, because on this FI we have 2104 and 2208. For 2208, I reset the links with port channel after the discovery.
My UCS system is with the last version of firmware.
Stéphane
Stéphane,
Once policy changed to individual links, decomission chassis 1 and re-commission it. If port-channel is not deleted then, please open support case with TAC and indicate actions that you have taken.
Hi Dmitri,
I already decommissioned the chassis, but the PO was always there
I will contact the support.
