no compatible network adapters found esxi 5.1
Dragomir
not sure what happened but when i rebooted my esxi 5.1 host i am getting a
no compatible network adapters found esxi 5.1 message and there is not nic adapters.
in the sevice profile , nothing has changed. just 2 vnics, vnic0,vnic1
any ideas?
6 Replies 6
Keny Perez
Level 8
Level 8
Tony,
OK that is from the OS perspetive, what does UCSM say?
Any screenshots for errors ?
-Kenny
Manuel Velasco
Can you provide a screenshot of what you see?
What adapter do you have installed?
What is the firmware installed on this blade?
this is the UCS-VIC-M82-8P card, UCS B200M2
firmware is 2.1(1a)
another blade same specs is working fine. service profile is identical.
esxcfg-nics -l is showing nothing on the host
What are the CIMC, adapter and bios versions for this blade?
this is what i see on the blade
Tony,
I would've suspect of this bug
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCue66095, but you said the host does not see the nic either.
Is there any dynamic vnic policy applied to the service profile?
-Kenny
