No Hyperflex plugin shown on vCenter
We have deployed Hyperflex 4.0.1b on vCenter VMware-VCSA-all-6.7.0-14070457
We finished the deployment successfully and cluster is online and healthy
The problem is that I can't find the Hyperflex plugin when navigating to vCenter Global inventory list as attached
I think it should appear under Distributed Switches
Is below link should solve this problem or I still need to install something
https://www.cisco.com/c/en/us/support/docs/hyperconverged-infrastructure/hyperflex-hx-data-platform/213686-troubleshooting-hyperflex-plugin-issues.html
RedNectar
Hi @Hythim Ali El Hadad ,
The most likely problem is that the plug-in ONLY works on the Flash/Flex version of vCenter. We are all waiting anxiously for HXDP v4.02 which we've been promised will have an HTML5 user interface.
If this doesn't fix your problem, you may have to restart the vCenter appliance.
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
I hope this helps
Great RedNectar
It works .
Only I have another question here to confirm from you
I have shutdown the cluster following the guideline from Cisco by stcli cluster shutdown then power off the controller VMs then the hosts
After power up the cluster, I found it is offline untill I start it with " stcli cluster start "
Also one Datastore was unmounted to 1 of the 3 ESXi hosts
Is there an automatic way that let the cluster start automatically after a maintenance or power outage ?
Also I remount the Datastore, Is this Datastore behavior is normal and will this affect us while in production ?
Haitham
I didn't answer immediately because I was hoping somone with more inside knowledge than me might be able to give a better answer (it is probably worth posting a new question)
I'll give it a shot, but I have not researched this, so this is my "current understanding"
In the event of a power failure, the cluter should recover by itself. You should not have to issue a stcli cluster start
If you have manually shut down the cluster (stcli cluster shutdown) the cluster will stay down until it is manually restarted.  I have not found an exact explanation, but I do know that you use this command if you need to change the cluster from VSI optimised to VDI optimised (or vice versa - see
Cisco HyperFlex Systems Installation Guide for VMware ESXi, Release 4.0) during which time you have to edit files on each ESXi host.  To my way of thinking, if there was a power outage during this process, you would NOT want the cluster to try and restart untill you had manullay restarted, so I think the idea that you MUST do a stcli cluster start after a stcli cluster shutdown is a good idea.
