Hi, everyone:
could you please help me to solve kvm cannot logint issure ? try many way and has ever configure KVM ip address, according to the following
step "In the navigation pane, click the LAN tab, expand LAN > Pools > root > IP Pools, and then choose IP Pool ext-mgmt."
error message is attachment file.
Solved! Go to Solution.
Which version are you running now ?
Maybe it is worth upgrading the whole mini UCS system.
Software can be downloaded from
https://software.cisco.com/download/release.html?mdfid=283853163&catid=282558030&softwareid=283655681&release=3.1(2b)&relind=AVAILABLE&rellifecycle=&reltype=latest
The CIMC software is in the .B package
Software for the UCS B-Series blade server products ucs-k9-bundle-b-series.3.1.2b.B.bin |
17-SEP-2016 | 464.42 MB |
All the details can be found in
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-manager/GUI-User-Guides/Firmware-Mgmt/3-1/b_UCSM_GUI_Firmware_Management_Guide_3_1/b_UCSM_GUI_Firmware_Management_Guide_3_1_chapter_011.html#concept_A0775BBAB0894FF592A3FAB0D71B8B1D
Activate the firmware.
The activation of firmware for a CIMC does not disrupt data traffic. However, it will interrupt all KVM sessions and disconnect any vMedia attached to the server.
- Can you please verify, that CIMC has an IP address out of this pool (you can check the pool, and see which blade slot has which IP address)
- can you ping this CIMC IP address from where you try the KVM session
- try to reset CIMC
Xiazhen,
What is the current running version of Java on the machine used to access KVM?
Are you experiencing this issue on other machines?
What is the current running version of UCS Manager?
Can you KVM to any blades in the domain?
hi,Paul Felts :
Q: What is the current running version of Java on the machine used to access KVM?
A: C:\Program Files (x86)\Java\jre7\bin>java.exe -version
java version "1.7.0_79"
Java(TM) SE Runtime Environment (build 1.7.0_79-b15)
Java HotSpot(TM) Client VM (build 24.79-b02, mixed mode, sharing)
Q: Are you experiencing this issue on other machines?
A: for UCS mini, total two B200m3 blade server. all of the two B200 blade server cannot
kvm console login, the same error messages.
Q: What is the current running version of UCS Manager?
A: 3.1(2B).
Q: Can you KVM to any blades in the domain?
A: cannot.
from xia zhen
Q. why do have such a strange default GWY ? ususally this is .1 or .254
Q. are your FI's IP address in the same C-class IP network ? which they must be !
hi,Walter Dey:
A: the ip address 10.10.1.246 is right gateway. just ensure with network
administrator.
A: yes .for FI's IP address and KVM's ip is same network. please refer attachment file.
so strange issure, try many ways,waste a long time. also cannot solve it .
what'swrong with kvm.ask for another issure. can i skip kvm ? directly connect
LCD monitor to install operation system ?
from xia zhen.
This is really very odd ?
Could it be a duplicate IP address ?
Remote the blade from the chassis, and ping this address again. If it replies, it is a duplicate one.
hi,walter dey:
thank you for helping me , have already ensure , no duplicate IP address for blade.
from xia zhen.
hi, walter dey:
could you help me again ? just look for bug search tool , display it's a bug
about CIMC version. please refer following article:
so my question is : how to only update CIMC version ? where can download
CIMC firmware ? for UCSM , the current version : 3.1(2b)
hi , expert:
for UCSM version: ucs-mini-k9-bundle-infra.3.1.2b.A.bin
for CIMC version: 3.0(1C)。
and could you please telling me how to only upgrade CMIC firmware ?
from xiazhen
hi,walter Dey:
could you please help me ? how to reset CIMC ? CIMC IP is ping successfully .
from xiazhen
