AS5300 not detecting E1 voice port
olakayode
We have an AS5300 with 4E1s. When the E1 PRI timeslots are enabled, the voice port is not enabled/detected.
The image on the AS5300 is c5300-js-mz.122-26.bin.
Pls assist!!!
5 Replies 5
nikhil_m
This could be due to image. You can download the latest one and try
I've already done this and it didn't detect it.
fbadr
i didnt check your image but did you choose IP plus as image?
pacameron
Level 4
Level 4
Make sure you have the Voice feauture cards installed and they have the DSP modules mounted on them.
Send a SH VER, SH RUN, SH VFC 1 DIR and SH VFC 2 DIR so we can confirm your hardware configuration
There are no VFCs installed. This is the sh ver and sh run from the AS5300.
Router#sh ver
IOS (tm) 5300 Software (C5300-IS-M), Version 12.1(3a)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Sat 29-Jul-00 14:18 by ccai
Image text-base: 0x60008958, data-base: 0x60DD2000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
BOOTFLASH: 5300 Software (C5300-BOOT-M), Version 12.2(15)T13, RELEASE SOFTWARE
(fc2)
Router uptime is 38 minutes
System returned to ROM by reload at 17:06:05 UTC Sat Dec 11 2004
System image file is "flash:c5300-is-mz_121-3a_T1.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory
Processor board ID 21689700
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.1, Item Number 800-2544-03,
Board Revision D0, Serial Number 21689700,
PLD/ISP Version 0.0, Manufacture Date 30-Jul-2000.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
72 terminal line(s)
4 Channelized E1/PRI port(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Configuration register is 0x102
Router#sh run
Building configuration...
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname Router
spe 1/0 1/5
firmware location system:/ucode/mica_port_firmware
resource-pool disable
ip subnet-zero
mta receive maximum-recipients 0
controller E1 0
clock source line primary
controller E1 1
clock source line secondary 1
controller E1 2
clock source line secondary 2
controller E1 3
clock source line secondary 3
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
no fair-queue
clockrate 2015232
interface Serial1
no ip address
shutdown
no fair-queue
clockrate 2015232
interface Serial2
no ip address
shutdown
no fair-queue
clockrate 2015232
interface Serial3
no ip address
shutdown
no fair-queue
clockrate 2015232
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
ip classless
no ip http server
line con 0
transport input none
line 1 72
line aux 0
line vty 0 4
end
Router#
Thank you.
