AS5400XM Setting the Bind Command at the Dial-peer Level
mathieuploton
I am unable to find the command to set the Bind Command at the Dial-peer Level...
It seems to be supported in 12.4T (http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-bind_ps6441_TSD_Products_Configuration_Guide_Chapter.html)
On both of my gateways, the command is not here...
Version : c5400-is-mz.124-15.T10
and
Version : c5400-jk9su2_ivs-mz.124-24.T3.bin
Just to give an overview, the voip gateways are connected to a huawei media gateway that can only charge based on source address. So as I want to have multiple voip providers connected to my cisco gateway, I like to bind the dialpeer to a loopback per provider. This way, the huawei core will see the calls coming from different ip addresses and be able to charge accordingly.
Let me know if this is something achievable,
Steven Holl
Per dial-peer bind came with 15.1T somewhere.  Just run 15.1(4)M and you should be fine.
I found this command in 12.4T :
voice-class source interface loopback
It seems that is pretty much the same, isn't it ?
Yeah that look like it is it; I must hae been mixing it up with the feature to match inbound dial-peers on remote IP which came later.
12.4(22)T, 12.4(24)T, and all 15.x code will have that command.
