Call Manager 7 Intercom as broadcast
wdiclo
I have installed a Call Manager 7.0 and activated the intercom feature, but my client needs this feature to be able to work for a group of phones, instead of just a single phone.
For example, if a user wants to spread a company wide message via intercom, all user phones that are configured with the intercom, can hear the message.
Is this possible or are limited to having an intercom communication with just to parties?
Wilfred Diclo
Senior Project Engineer
GTEC C x A
Adrian Saavedra
Level 7
Level 7
What you want is called paging. CUCM doesn't have this feature. You need 3rd party products.
Hope to help, if it does please rate.
Best regards,
-- Adrián.
CUCM Intercom is point-to-point only.  You need a broadcast paging application.  It would also be to your advantage to ensure your network is multicast-enabled as most of these applications are going to require multicast to function properly and be scalable.  Check out www.cistera.com.
Please rate helpful posts!
