Cisco 2811 SIP-to-SIP GW T.38 does not work!
Ellad Yatsko
Hello!
Diagram is something like this:  Softswitch(MERA) -->>-- Cisco2811 -->>-- Softswitch(MERA)   It's needed to limit traffic if one of SSWs is hacked. But it is not a subject. We just need such "construction".
Previously there was Cisco 1760 instead of 2811, result was the same. So I exclude platform and IOS.
1. Voice calls are sent and received fine in diagram above.
2. Fax are passed good between two Softswitches if I exclude Cisco2811.
3. Faxes are stopped immediately when I re-route voice traffic through Cisco2811 (in the same conditions on both Softswitches as in above paragraph 2. That is, Faxes are passed between Softswitches directly, I don't change anything on Softswitches, and I just re-route Voice from both Softswitches on C2811 - Faxes stop immediately).
4. Relevant configuraion:
voice service voip
allow-connections sip to sip
voice class uri  Centrex sip
host ^10\.0\.99\.111$
voice class uri  RTU1 sip
host ^10\.0\.99\.121$
voice class uri  RTU2 sip
host ^10\.0\.99\.221$
voice class codec 1
codec preference 1 g711alaw bytes 80
codec preference 2 clear-channel
voice translation-rule 112
rule 1 /^000112\(.*\)$/ /\1/
voice translation-rule 999
rule 1 /^999\(.*\)$/ /000\1/
voice translation-rule 999112
rule 1 /^\(.*\)$/ /999112\1/
voice translation-profile 112
translate called 112
voice translation-profile 999
translate called 999
voice translation-profile 999112
translate called 999112
interface FastEthernet0/0.18
encapsulation dot1Q 18
ip address 10.0.99.29 255.255.255.0
no snmp trap link-status
dial-peer voice 999112 voip
translation-profile incoming 999112
voice-class codec 1
session protocol sipv2
incoming uri from Centrex
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 9600
fax nsf 000000
fax protocol t38 ls-redundancy 3 hs-redundancy 0 fallback pass-through g711alaw
no vad
dial-peer voice 999 voip
translation-profile outgoing 999
destination-pattern 999.+
voice-class codec 1
session target ipv4:10.0.99.99
session transport udp
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 112 voip
translation-profile outgoing 112
destination-pattern 000112.+
voice-class codec 1
session target ipv4:10.0.99.100
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 901 voip
voice-class codec 1
incoming uri from RTU1
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 902 voip
voice-class codec 1
incoming uri from RTU2
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
5. TSHARK from left-side Softswitch:
16:10:51.680764  10.0.99.221 -> 10.0.99.29   SIP/SDP Request: INVITE sip:0001124957887603@10.0.99.29;user=phone, with session description
16:10:51.721616   10.0.99.29 -> 10.0.99.221  SIP Status: 100 Trying
16:10:55.413288   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 183 Session Progress, with session description
16:10:55.418718   10.0.99.29 -> 10.0.99.221  SIP Status: 180 Ringing
16:10:59.090481   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 200 OK, with session description
16:10:59.091451  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:04.296532   10.0.99.29 -> 10.0.99.221  SIP Status: 488 Not Acceptable Media
16:11:04.296708  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:04.793058   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 200 OK, with session description
16:11:04.793262  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:05.793043   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 200 OK, with session description
16:11:05.793261  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:07.793042   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 200 OK, with session description
16:11:07.793300  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:11.793077   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 200 OK, with session description
16:11:11.793264  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:15.793316   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 200 OK, with session description
16:11:15.793541  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:19.793289   10.0.99.29 -> 10.0.99.221  SIP/SDP Status: 200 OK, with session description
16:11:19.793538  10.0.99.221 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
16:11:23.794963   10.0.99.29 -> 10.0.99.221  SIP Request: BYE sip:4991589848@10.0.99.221:5061;user=phone
16:11:23.795650  10.0.99.221 -> 10.0.99.29   SIP Status: 200 OK
6. TSHARK from right-side Softswitch:
16:10:12.071247  10.0.99.111 -> 10.0.99.29   SIP/SDP Request: INVITE sip:4957815696@10.0.99.29;user=phone, with session description
16:10:12.113708   10.0.99.29 -> 10.0.99.111  SIP Status: 100 Trying
16:10:12.843352   10.0.99.29 -> 10.0.99.111  SIP/SDP Status: 183 Session Progress, with session description
16:10:16.328955   10.0.99.29 -> 10.0.99.111  SIP/SDP Status: 200 OK, with session description
16:10:16.329808  10.0.99.111 -> 10.0.99.29   SIP Request: ACK sip:4957815696@10.0.99.29:5060
16:10:51.721600   10.0.99.29 -> 10.0.99.100  SIP/SDP Request: INVITE sip:4957887603@10.0.99.100:5060, with session description
16:10:51.723145  10.0.99.100 -> 10.0.99.29   SIP Status: 100 Trying
16:10:55.384493  10.0.99.100 -> 10.0.99.29   SIP/SDP Status: 183 Progress, with session description
16:10:55.392178  10.0.99.100 -> 10.0.99.29   SIP Status: 180 Ringing
16:10:59.069771  10.0.99.100 -> 10.0.99.29   SIP/SDP Status: 200 OK, with session description
16:10:59.088587   10.0.99.29 -> 10.0.99.100  SIP Request: ACK sip:4957887603@10.0.99.100:5060
7. Debug output for "debug ccsip all" and "debug voice dialpeer all"
Router#
*Sep 19 12:27:55.107: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x4654DA30,addr=10.0.99.111
*Sep 19 12:27:55.267: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:27:55.267: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:27:55.267: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
*Sep 19 12:27:55.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0001124957887603@10.0.99.29;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.0.99.221:5061;rport;branch=z9hG4bK-3628481038-3792786178-436258467-408012644
From: <sip:4991589848@10.0.99.221:5061;user=phone>;tag=4095425038-3792786178-436258467-408012644
To: <sip:0001124957887603@10.0.99.29;user=phone>
Call-ID: 0e3a1c30025311e2a3c6001a64c75118@10.0.99.221
CSeq: 1 INVITE
Contact: <sip:4991589848@10.0.99.221:5061;user=phone>
Content-Type: application/sdp
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, REFER, REGISTER, UPDATE
Max-Forwards: 70
User-Agent: MERA MVTS3G v.4.4.0-15
Cisco-Guid: 237931618-38998498-2747662362-1690784024
Category: 10
Content-Length:   313
v=0
o=- 1348056651 1348056651 IN IP4 10.0.99.221
s=-
c=IN IP4 10.0.99.221
t=0 0
m=audio 17294 RTP/AVP 8 0 18 4 96
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:4 G723/8000
a=fmtp:4 annexa=yes
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
a=sendrecv
*Sep 19 12:27:55.267: //-1/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Sep 19 12:27:55.267: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:27:55.267: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:27:55.271: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4627A3B8 key=0e3a1c30025311e2a3c6001a64c75118@10.0.99.2210001124957887603
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 0001124957887603
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 4991589848
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name , number 4991589848, Calling oct3 0x00, oct_3a 0x80, Called number 0001124957887603
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4991589848, Called Number=0001124957887603, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:0001124957887603@10.0.99.29;user=phone
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
*Sep 19 12:27:55.271: //-1/0E2E8C62A3C6/DPM/dpMatchPeertype:exit@5392
   Match Rule=DP_MATCH_TO_URI; URI=sip:0001124957887603@10.0.99.29;user=phone
   Result=-1
   Match Rule=DP_MATCH_FROM_URI; URI=sip:4991589848@10.0.99.221:5061;user=phone
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=902 Is Matched
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/DPM/dpMatchPeertype:exit@5392
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_FROM_URI; Incoming Dial-peer=902
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/DPM/dpAssociateIncomingPeerSPI:exit@5926
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/SIP/Info/sipSPIGetCallConfig: Peer tag 902 matched for incoming call
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/SIP/Info/sipSPICopyPeerDataToCCB:
From CLI: Modem NSE payload = 100, Passthrough = 0, Modem relay = 0, Gw-Xid = 1
SPRT latency 200, SPRT Retries = 12, Dict Size = 1024
String Len = 32, Compress dir = 3
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/SIP/Info/sipSPIContinueNewMsgInvite: Calling name , number 4991589848, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 0001124957887603, oct3 0x00
*Sep 19 12:27:55.275: //-1/0E2E8C62A3C6/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(96) could not be reserved.
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY payload (96) is reserved by another application.
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY option(s) not found in Preferred DTMF-RELAY option list!
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIStreamTypeAndDtmfRelay: DTMF Relay mode: Inband Voice
*Sep 19 12:27:55.275: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=8, codec_bytes=80, codec=g711alaw, dtmf_relay=inband-voice
        stream_type=voice-only (0), dest_ip_address=10.0.99.221, dest_port=17294
*Sep 19 12:27:55.275: //19/0E2E8C62A3C6/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711alaw, bytes :80
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 19 peer 0 flags 0x201
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 19, sdp 0x45A61FCC channels 0x4627BC80
SIP: (19) Attribute ptime, level 1 instance 1 not found.
Hndl ptype 8 mline 1
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Sep 19 12:27:55.279: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=80, coverted ptime=10 stream->mline_index=1, media_ndx=1
Adding codec 6 ptype 8 time 10, bytes 80  as channel 0 mline 1 ss 0 10.0.99.221:17294
Hndl ptype 0 mline 1
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=0, media_ndx=1
*Sep 19 12:27:55.279: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :0, codecbytes: 0
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 160
Adding codec 5 ptype 0 time 0, bytes 160  as channel 1 mline 1 ss 0 10.0.99.221:17294
Hndl ptype 18 mline 1
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
Router#P/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8 pre-ietf
*Sep 19 12:27:55.279: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g729r8 pre-ietf ptime :0, codecbytes: 0
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 20
Adding codec 0 ptype 18 time 0, bytes 20  as channel 2 mline 1 ss 0 10.0.99.221:17294
Hndl ptype 4 mline 1
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPISelectCodecVersion: Codec (g723ar63) is not in preferred list
*Sep 19 12:27:55.279: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 0 ptype 4 time 0, bytes 20  as channel 3 mline 1 ss 0 10.0.99.221:17294
Hndl ptype 96 mline 1
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/copy_channels:
callId 19 size 296 ptr 0x46646D94)
CCSIP: Unable to report channel ind
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice-only
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Callid                 : -1
          Negotiated Codec       : g711alaw, bytes :80
          Negotiated DTMF relay  : inband-voice
          Negotiated NTE payload : 0
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : 10.0.99.29:0
          Media Dest Addr/Port   : 10.0.99.221:17294
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPIHandleInviteMedia:
Preferred  DTMF relay 1 : 6
Preferred  DTMF relay 2 : 0
Negotiated DTMF relay   : 0
Preferred and Negotiated NTE payloads: 101 0
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPIDoQoSNegotiation: SDP body with media description
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Sep 19 12:27:55.283: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 19570 for stream 1
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=19570
*Sep 19 12:27:55.283: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 19570
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = 0e3a1c30025311e2a3c6001a64c75118@10.0.99.221
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
*Sep 19 12:27:55.283: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
*Sep 19 12:27:55.283: //19/0E2E8C62A3C6/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
*Sep 19 12:27:55.287: //19/0E2E8C62A3C6/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4627A3B8 key=0e3a1c30025311e2a3c6001a64c75118@10.0.99.221114FC0-1F24
*Sep 19 12:27:55.287: //19/0E2E8C62A3C6/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 13 to table
*Sep 19 12:27:55.287: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654E450, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:27:55.287: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:27:55.287: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:27:55.287: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654E450, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:27:55.287: //19/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
*Sep 19 12:27:55.287: //19/0E2E8C62A3C6/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.0.99.221:5061
*Sep 19 12:27:55.287: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
*Sep 19 12:27:55.291: //-1/0E2E8C62A3C6/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0001124957887603, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=0001124957887603
*Sep 19 12:27:55.291: //-1/0E2E8C62A3C6/DPM/dpMatchCore:
   Dial String=0001124957887603, Expanded String=0001124957887603, Calling Number=
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Sep 19 12:27:55.291: //-1/0E2E8C62A3C6/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=112 Is Matched
   Result=Success(0) after DP_MATCH_DEST
*Sep 19 12:27:55.291: //-1/0E2E8C62A3C6/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=112
*Sep 19 12:27:55.291: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Sep 19 12:27:55.291: //20/000000000000/SIP/Info/ccsip_call_setup_request:
This a IPIP call: Chan 0, codec 6 channel 17294, ip A0063DD:17294  params 0x465F9EF4 caps 0x44ED30C8
This a IPIP call: Chan 1, codec 5 channel 17294, ip A0063DD:17294  params 0x465F9EF4 caps 0x44ED30C8
This a IPIP call: Chan 2, codec 0 channel 17294, ip A0063DD:17294  params 0x465F9EF4 caps 0x44ED30C8
This a IPIP call: Chan 3, codec 0 channel 17294, ip A0063DD:17294  params 0x465F9EF4 caps 0x44ED30C8
*Sep 19 12:27:55.291: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
*Sep 19 12:27:55.291: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Sep 19 12:27:55.291: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 137)
*Sep 19 12:27:55.291: //19/0E2E8C62A3C6/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 20 chans 0x44EE3BB0 event 137 flags 0x10020038 0x601 data 0x44EE3BB0
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 20 chans 0x44EE3BB0 event 137 flags  0x10020038 0x601 data 0x44EE3BB0
*Sep 19 12:27:55.295: //19/0E2E8C62A3C6/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 20 chans 0x44EE3BB0 event 137 flags 0x10020038 0x601 data 0x44EE3BB0, type = 3
*Sep 19 12:27:55.295: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 14 to table
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/act_idle_continue_call_setup:
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPICopyPeerDataToCCB:
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 20, channels 0x44E96BE0 caps 0x44ED30C8
pref dtmf 96
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4627C64C key=45D1BE07-18C11E2-80158018-61678721@10.0.99.29
*Sep 19 12:27:55.295: //20/000000000000/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 45D1BE07-18C11E2-80158018-61678721@10.0.99.29
*Sep 19 12:27:55.295: //20/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:27:55.295: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16926 for stream 1
*Sep 19 12:27:55.299: //20/000000000000/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
*Sep 19 12:27:55.299: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Sep 19 12:27:55.299: //20/000000000000/SIP/Info/sip_generate_sdp_xcaps
Router#_list: Modem Relay and T38 disabled. X-cap not needed
*Sep 19 12:27:55.299: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Sep 19 12:27:55.299: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:27:55.299: //20/000000000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
*Sep 19 12:27:55.299: //20/000000000000/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
*Sep 19 12:27:55.299: //20/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Sep 19 12:27:55.299: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4654D520, addr=10.0.99.100, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41086470
*Sep 19 12:27:55.299: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:27:55.299: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:27:55.299: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4654D520
*Sep 19 12:27:55.299: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654D520, addr=10.0.99.100, port=5060, connId=3 for UDP
*Sep 19 12:27:55.299: //20/000000000000/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
*Sep 19 12:27:55.303: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
*Sep 19 12:27:55.303: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
*Sep 19 12:27:55.303: //20/000000000000/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Sep 19 12:27:55.303: //20/000000000000/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 20) to the VOIP RTP library
*Sep 19 12:27:55.303: //20/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:27:55.303: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Sep 19 12:27:55.303: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 16926, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 20, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
        media_ip_addr = 0.0.0.0
*Sep 19 12:27:55.303: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Sep 19 12:27:55.303: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <sip:0001124957887603@10.0.99.29;user=phone>;tag=114FC0-1F24
Date: Wed, 19 Sep 2012 12:27:55 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Sep 19 12:27:55.307: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4957887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1C14C0
To: <sip:4957887603@10.0.99.100>
Call-ID: 45D1BE07-18C11E2-80158018-61678721@10.0.99.29
Supported: 100rel,timer,replaces
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <sip:4991589848@10.0.99.29>;party=calling;screen=no;privacy=off
Timestamp: 1348057675
Contact: <sip:4991589848@10.0.99.29:5060>
Expires: 180
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 3284 8564 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 16926 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:10
*Sep 19 12:27:55.307: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Sep 19 12:27:55.307: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:27:55.311: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Contact: <sip:4957887603@10.0.99.100:5060>
Server: MERA MVTS3G v.4.4.0-15
Content-Length: 0
*Sep 19 12:27:55.311: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Router#
*Sep 19 12:27:58.971: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Sep 19 12:27:58.971: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:27:58.971: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Progress
To: <sip:4957887603@10.0.99.100>;tag=2318849048-3792786178-436251047-2287060836
CSeq: 101 INVITE
Content-Length:   239
v=0
o=- 1348056655 1348056655 IN IP4 10.0.99.111
s=-
c=IN IP4 10.0.99.111
t=0 0
m=audio 21550 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:10
a=sendrecv
a=silenceSupp:off - - - -
*Sep 19 12:27:58.971: //20/000000000000/SIP/Info/HandleSIP1xxSessionProgress: Content-Disposition NOT received in 18x response - using default Content-Disposition values
*Sep 19 12:27:58.971: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Sep 19 12:27:58.971: //20/000000000000/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Sep 19 12:27:58.971: //20/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*Sep 19 12:27:58.971: //20/000000000000/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:10
*Sep 19 12:27:58.975: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :10, codecbytes: 80
*Sep 19 12:27:58.975: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved.
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: Payload type (101) is reserved for requested dtmf relay mode.
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*Sep 19 12:27:58.975: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=8, codec_bytes=80, codec=g711alaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=10.0.99.111, dest_port=21550
*Sep 19 12:27:58.975: //20/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
*Sep 19 12:27:58.975: //20/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 20 peer 19 flags 0x7
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 20, sdp 0x45C92F44 channels 0x4627DF14
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=10,stream->negotiated_codec_bytes=80, coverted ptime=10 stream->mline_index=1, media_ndx=1
Adding codec 6 ptype 8 time 10, bytes 80  as channel 0 mline 1 ss 1 10.0.99.111:21550
Hndl ptype 101 mline 1
*Sep 19 12:27:58.975: //20/000000000000/SIP/Info/copy_channels:
callId 20 size 80 ptr 0x46655B7C)
*Sep 19 12:27:58.975: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Sep 19 12:27:58.975: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 131)
*Sep 19 12:27:58.975: //19/0E2E8C62A3C6/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 20 chans 0x46655B7C event 131 flags 0x10020038 0x403 data 0x46655B7C
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 20  chans 0x46655B7C event 131 flags 0x10020038 0x403 data 0x46655B7C
*Sep 19 12:27:58.979: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 20 chans 0x46655B7C event 131 flags 0x10020038 0x403 data 0x46655B7C
*Sep 19 12:27:58.979: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=-1, current_seq_num=0x1A8
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=-1, current_seq_num=0x0
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711alaw, Bytes=80
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=1161273728, from CLI config=0
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Error/sipSPISetStreamInfo: Number of active streams is zero (0)!
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711alaw, Bytes=80
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->flags_ipip = 0x403
*Sep 19 12:27:58.979: //20/000000000000/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
*Sep 19 12:27:58.979: //20/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          Callid                 : 20
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101
          Media Srce Addr/Port   : 10.0.99.29:16926
          Media Dest Addr/Port   : 10.0.99.111:21550
*Sep 19 12:27:58.979: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Sep 19 12:27:58.979: //20/000000000000/SIP/Info/HandleSIP1xxSessionProgress: ccsip_api_call_cut_progress returned: SIP_SUCCESS
*Sep 19 12:27:58.979: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Sep 19 12:27:58.979: //20/000000000000/SIP/Info/HandleSIP1xxSessionProgress: Transaction Complete. Lock on Facilities released.
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 19 ft: 1, inc 8, 10.0.99.111:21550, codec 6
*Sep 19 12:27:58.979: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 19, channels 0x46655B7C caps 0x44E8F284
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
pref dtmf 101
nego mline 1 dtmf 101 ss 1 ret 0
*Sep 19 12:27:58.983: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
retreive codec 6 ptype 8 time 10 bytes 80
*Sep 19 12:27:58.983: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 19570
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Sep 19 12:27:58.983: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROGRESS
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Info/ccsip_bridge: confID = 10, srcCallID = 19, dstCallID = 20
Router#o/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 19/20
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=19
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 19) to the VOIP RTP library
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Sep 19 12:27:58.983: //19/0E2E8C62A3C6/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 19570, raddr = 10.0.99.221, rport=17294, do_rtcp=TRUE
        src_callid = 19, dest_callid = 20, stream type = voice+dtmf, stream direction = SENDRECV
        media_ip_addr = 10.0.99.221
*Sep 19 12:27:58.987: //19/0E2E8C62A3C6/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Sep 19 12:27:58.987: //19/0E2E8C62A3C6/SIP/Info/sipSPIUpdateRtcpSession: Process Media changes is still pending.
*Sep 19 12:27:58.987: //19/0E2E8C62A3C6/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDRECV
        Present Local Media Direction = SENDRECV
        New Local Media Direction = SENDRECV
        retVal = 0
*Sep 19 12:27:58.987: //20/000000000000/SIP/Info/ccsip_bridge: confID = 10, srcCallID = 20, dstCallID = 19
*Sep 19 12:27:58.987: //20/000000000000/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 20/19
*Sep 19 12:27:58.987: //20/000000000000/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=20, new streamcallid=20
*Sep 19 12:27:58.987: //20/000000000000/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Sep 19 12:27:58.987: //20/000000000000/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 20) to the VOIP RTP library
*Sep 19 12:27:58.987: //20/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:27:58.987: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Sep 19 12:27:58.987: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 16926, raddr = 10.0.99.111, rport=21550, do_rtcp=TRUE
        src_callid = 20, dest_callid = 19, stream type = voice+dtmf, stream direction = SENDRECV
        media_ip_addr = 10.0.99.111
*Sep 19 12:27:58.987: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
*Sep 19 12:27:58.987: //20/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Sep 19 12:27:58.991: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Sep 19 12:27:58.991: //19/0E2E8C62A3C6/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Sep 19 12:27:58.991: //19/0E2E8C62A3C6/SIP/Info/sipSPISendInviteResponse183: Session Type is Media/Qos/Security/RTR SDP body is attached
*Sep 19 12:27:58.991: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 183 Response to the Transport Layer
*Sep 19 12:27:58.991: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DFD0, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x41086D90
*Sep 19 12:27:58.991: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:27:58.991: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:27:58.991: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DFD0, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:27:58.991: //19/0E2E8C62A3C6/SIP/Info/sentInviteResponse18x: Sent a 18x Response
*Sep 19 12:27:58.991: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:27:58.991: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
*Sep 19 12:27:58.995: //20/000000000000/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
*Sep 19 12:27:58.995: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Sep 19 12:27:58.995: //20/000000000000/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
*Sep 19 12:27:58.995: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Sep 19 12:27:58.995: //20/000000000000/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
*Sep 19 12:27:58.995: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
CSeq: 1 INVITE
Contact: <sip:0001124957887603@10.0.99.29:5060>
Content-Disposition: session;handling=required
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 4191 6681 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 19570 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:27:58.999: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
*Sep 19 12:27:58.999: //19/0E2E8C62A3C6/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Sep 19 12:27:58.999: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*Sep 19 12:27:58.999: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DFD0, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x41086D90
*Sep 19 12:27:58.999: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:27:58.999: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:27:58.999: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DFD0, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:27:58.999: //19/0E2E8C62A3C6/SIP/Info/sentInviteResponse18x: Sent a 18x Response
*Sep 19 12:27:58.999: //19/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_SENT_ALERTING, SUBSTATE_NONE)
*Sep 19 12:27:59.003: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Content-Length: 0
Router#
*Sep 19 12:28:02.655: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Sep 19 12:28:02.655: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:02.655: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, REFER, REGISTER, SUBSCRIBE, UPDATE
X-mera-expires: 86460
Content-Length:   239
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:10
a=sendrecv
*Sep 19 12:28:02.659: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:10
*Sep 19 12:28:02.659: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :10, codecbytes: 80
*Sep 19 12:28:02.659: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*Sep 19 12:28:02.659: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sip_do_nse_negotiation: Remote NSE payload = local one = 0, Use it
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
*Sep 19 12:28:02.659: //20/000000000000/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=21550 new=21550
*Sep 19 12:28:02.659: //20/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Sep 19 12:28:02.659: //20/000000000000/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No
*Sep 19 12:28:02.659: //20/000000000000/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
*Sep 19 12:28:02.659: //20/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : No
        DSP DNLD Reqd          : No
*Sep 19 12:28:02.659: //20/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 20 peer 19 flags 0x407
*Sep 19 12:28:02.659: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 20, sdp 0x45CB1F40 channels 0x4627DF14
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Sep 19 12:28:02.663: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=10,stream->negotiated_codec_bytes=80, coverted ptime=10 stream->mline_index=1, media_ndx=1
*Sep 19 12:28:02.663: //20/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          State                  : STREAM_ACTIVE (5)
          Callid                 : 20
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
*Sep 19 12:28:02.663: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Sep 19 12:28:02.663: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer:
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
*Sep 19 12:28:02.663: //20/000000000000/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
*Sep 19 12:28:02.663: //20/000000000000/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
*Sep 19 12:28:02.663: //20/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Sep 19 12:28:02.663: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4654D880, addr=10.0.99.100, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41087AE4
*Sep 19 12:28:02.663: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:02.663: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:02.663: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4654D880
*Sep 19 12:28:02.663: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654D880, addr=10.0.99.100, port=5060, connId=3 for UDP
*Sep 19 12:28:02.663: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
*Sep 19 12:28:02.667: //20/000000000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4627C64C
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 4991589848
Called Number            : 4957887603
Source IP Address (Sig  ): 10.0.99.29
Destn SIP Req Addr:Port  : 10.0.99.100:5060
Destn SIP Resp Addr:Port : 10.0.99.100:5060
Destination Name         : 10.0.99.100
*Sep 19 12:28:02.667: //20/000000000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 80
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101
Source IP Address (Media): 10.0.99.29
Source IP Port    (Media): 16926
Destn  IP Address (Media): 10.0.99.111
Destn  IP Port    (Media): 21550
Orig Destn IP Address:Port (Media): 0.0.0.0:0
*Sep 19 12:28:02.667: //20/000000000000/SIP/Info/sipSPICallActive: Transaction Complete. Lock on Facilities released.
*Sep 19 12:28:02.667: //20/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Sep 19 12:28:02.667: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
*Sep 19 12:28:02.667: //19/0E2E8C62A3C6/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Sep 19 12:28:02.671: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:02.671: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DC70, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x41087080
*Sep 19 12:28:02.671: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:02.671: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:02.671: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DC70, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:02.671: //19/0E2E8C62A3C6/SIP/Info/sentInviteResponse200: Sent 200Ok for Invite in state STATE_SENT_ALERTING
*Sep 19 12:28:02.671: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteResponse200: Transaction active. Facilities will be queued.
*Sep 19 12:28:02.671: //19/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE)  to (STATE_SENT_SUCCESS, SUBSTATE_NONE)
*Sep 19 12:28:02.671: //19/0E2E8C62A3C6/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Sep 19 12:28:02.671: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4957887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1D505
Router#
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Sep 19 12:28:02.675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 268
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:28:02.675: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:02.675: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:02.675: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:02.679: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0001124957887603@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.221:5061;rport;branch=z9hG4bK-2684396818-3792786178-436258467-408012644
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Sep 19 12:28:02.679: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:02.679: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:02.679: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities released.
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4627A3B8
Called Number            : 0001124957887603
Destn SIP Req Addr:Port  : 10.0.99.221:5061
Destn SIP Resp Addr:Port : 10.0.99.221:5061
Destination Name         : 10.0.99.221
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 19570
Destn  IP Address (Media): 10.0.99.221
Destn  IP Port    (Media): 17294
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/Info/sipSPICreateAndStartRtpTimer:
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 10.0.99.221, RTCP Type 3
*Sep 19 12:28:02.679: //19/0E2E8C62A3C6/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Router#
*Sep 19 12:28:07.859: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Sep 19 12:28:07.859: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:07.859: //20/000000000000/SIP/Info/ccsip_new_msg_preprocessor: ****Found CCB in UAC table
*Sep 19 12:28:07.859: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4991589848@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-3561377568-3792786178-436251047-22870608361
Via: SIP/2.0/UDP 10.0.99.100:5061;rport=5061;branch=z9hG4bK-3561377568-3792786178-436251047-2287060836;received=10.0.99.100
From: <sip:4957887603@10.0.99.100>;tag=2318849048-3792786178-436251047-2287060836
To: <sip:4991589848@10.0.99.29>;tag=114FE0-26C0
CSeq: 102 INVITE
Max-Forwards: 70
Content-Length:   193
v=0
o=- 1348056664 1348056664 IN IP4 10.0.99.111
s=-
t=0 0
m=image 21550 udptl t38
a=T38FaxRateManagement:transferredTCF
a=T38FaxUdpEC:t38UDPRedundancy
a=sendrecv
*Sep 19 12:28:07.863: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Sep 19 12:28:07.863: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:07.863: //20/000000000000/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
*Sep 19 12:28:07.863: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Sep 19 12:28:07.863: //20/000000000000/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Sep 19 12:28:07.863: //20/000000000000/SIP/Info/sipSPIDoFaxMediaNegotiation: T.38 negotiated
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=21550 new=21550
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPICompareMediaType: Media type switching from 0 to 11 for stream 1
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPICompareStreams: negotiated codec changed from g711alaw to T38Fax
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPICompareStreams: negotiated dtmf relay changed from rtp-nte to inband-voice
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : Yes
        DSP DNLD Reqd          : Yes
*Sep 19 12:28:07.863: //20/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:28:07.863: //20/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 20 peer 19 flags 0x4D0F
*Sep 19 12:28:07.867: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 20, sdp 0x45516EBC channels 0x4627DF14
Finished storing fax attrs 1 type 1 prot 0, rmgmt 1 maxbuff 0 max dgram 0
SIP: Attribute ptime, level 1 instance 1 not found.
Call 20 setting xmit func to udp
*Sep 19 12:28:07.867: //19/0E2E8C62A3C6/SIP/Info/ccsip_remote_codec_download_done:
callId 19 context 0x46647940
Call 20 set InfoType to FAX
*Sep 19 12:28:07.867: //-1/xxxxxxxxxxxx/SIP/Error/convert_codec_bytes_to_ptime: Unexpected VoIPCodec Type :T38Fax
*Sep 19 12:28:07.867: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: T38Fax codecbytes :20, ptime: 0
*Sep 19 12:28:07.867: //20/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=20, coverted ptime=0 stream->mline_index=1, media_ndx=1
Adding codec 17 ptype 0 time 0, bytes 20  as channel 0 mline 1 ss 0 10.0.99.111:21550
*Sep 19 12:28:07.867: //20/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report reINVITE media
*Sep 19 12:28:07.867: //20/000000000000/SIP/Info/copy_channels:
callId 20 size 80 ptr 0x44ECA9CC)
*Sep 19 12:28:07.867: //19/0E2E8C62A3C6/SIP/Info/ccsip_modify_media_ind: codec=0x10000 modem_redundancy=1175993460 callID 19 peer callID 20
*Sep 19 12:28:07.867: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_MEDIA_CHANGED
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          State                  : STREAM_CHANGING (4)
          Callid                 : -1
          Negotiated Codec       : T38Fax, bytes :20
*Sep 19 12:28:07.867: //20/000000000000/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 20) to the VOIP RTP library
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 16926, raddr = 10.0.99.111, rport=21550, do_rtcp=FALSE
*Sep 19 12:28:07.867: //20/000000000000/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Sep 19 12:28:07.871: //20/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Sep 19 12:28:07.871: //20/000000000000/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
*Sep 19 12:28:07.871: //20/000000000000/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
*Sep 19 12:28:07.871: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Sep 19 12:28:07.871: //20/000000000000/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 16926
*Sep 19 12:28:07.871: //20/000000000000/SIP/Info/sipSPI_ipip_build_t38_sdp:
*Sep 19 12:28:07.871: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*Sep 19 12:28:07.871: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
*Sep 19 12:28:07.871: //20/000000000000/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
*Sep 19 12:28:07.871: //20/000000000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
*Sep 19 12:28:07.871: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4654E3C0, addr=10.0.99.100, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:07.871: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:07.871: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:07.871: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654E3C0, addr=10.0.99.100, port=5060, connId=0 for UDP
*Sep 19 12:28:07.871: //20/000000000000/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.0.99.100:5060
*Sep 19 12:28:07.871: //19/0E2E8C62A3C6/SIP/Info/act_active_media_changed: New codec = 17
*Sep 19 12:28:07.875: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendErrorResponse: Sending ERROR Response to the transport layer
*Sep 19 12:28:07.875: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DC70, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:07.875: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:07.875: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:07.875: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DC70, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:07.875: //20/000000000000/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
*Sep 19 12:28:07.875: //20/000000000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
*Sep 19 12:28:07.875: //20/000000000000/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:07.875: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4654D0A0, addr=10.0.99.100, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x410Router#
*Sep 19 12:28:07.875: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:07.875: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:07.875: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654D0A0, addr=10.0.99.100, port=5060, connId=0 for UDP
*Sep 19 12:28:07.875: //20/000000000000/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
*Sep 19 12:28:07.875: //20/000000000000/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 10.0.99.111, RTCP Type 3
*Sep 19 12:28:07.875: //20/000000000000/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Sep 19 12:28:07.879: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-3561377568-3792786178-436251047-22870608361,SIP/2.0/UDP 10.0.99.100:5061;rport=5061;branch=z9hG4bK-3561377568-3792786178-436251047-2287060836;received=10.0.99.100
Date: Wed, 19 Sep 2012 12:28:07 GMT
CSeq: 102 INVITE
Remote-Party-ID: <sip:4991589848@10.0.99.29>;party=called;screen=no;privacy=off
Content-Length: 0
Sent:
SIP/2.0 488 Not Acceptable Media
Warning: 304 10.0.99.29 "Media Type(s) Unavailable"
CSeq: 1 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 151
v=0
o=CiscoSystemsSIP-GW-UserAgent 3284 8565 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=image 16926 udptl t38
c=IN IP4 10.0.99.29
*Sep 19 12:28:07.883: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:07.883: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Sep 19 12:28:07.883: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:07.883: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:07.887: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Sep 19 12:28:07.887: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:07.887: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:07.887: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
*Sep 19 12:28:07.887: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:07.887: //20/000000000000/SIP/Info/ccsip_new_msg_preprocessor: ****Found CCB in UAC table
Received:
ACK sip:4991589848@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-1223512608-3792786178-436251047-22870608361
Via: SIP/2.0/UDP 10.0.99.100:5061;rport=5061;branch=z9hG4bK-1223512608-3792786178-436251047-2287060836;received=10.0.99.100
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
*Sep 19 12:28:07.887: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Sep 19 12:28:07.887: //20/000000000000/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
*Sep 19 12:28:07.887: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
*Sep 19 12:28:07.891: //20/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer:
*Sep 19 12:28:07.891: //20/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
*Sep 19 12:28:08.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:08.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DD90, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:08.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:08.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:08.375: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DD90, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:08.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.99.221:5061;rport;branch=z9hG4bK-3628481038-3792786178-436258467-408012644
From: <sip:4991589848@10.0.99.221:5061;user=phone>;tag=4095425038-3792786178-436258467-408012644
Call-ID: 0e3a1c30025311e2a3c6001a64c75118@10.0.99.221
CSeq: 1 INVITE
Content-Type: application/sdp
Content-Length: 268
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:28:08.403: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:08.407: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:08.407: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:08.407: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
User-Agent: MERA MVTS3G v.4.4.0-15
Content-Length: 0
*Sep 19 12:28:08.407: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:08.407: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:08.407: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
*Sep 19 12:28:09.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:09.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654CDD0, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:09.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:09.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:09.375: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654CDD0, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:09.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 19 Sep 2012 12:28:08 GMT
Serv
Router#er: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Content-Length: 268
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:28:09.379: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:09.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:09.379: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:09.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Sep 19 12:28:09.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:09.379: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:09.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
Router#
*Sep 19 12:28:11.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:11.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654CEF0, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:11.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:11.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:11.375: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654CEF0, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:11.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 19 Sep 2012 12:28:09 GMT
CSeq: 1 INVITE
Content-Length: 268
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:28:11.379: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:11.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:11.379: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:11.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Sep 19 12:28:11.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:11.379: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:11.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
Router#
*Sep 19 12:28:15.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:15.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DD90, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:15.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:15.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:15.375: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DD90, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:15.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 19 Sep 2012 12:28:11 GMT
CSeq: 1 INVITE
Content-Length: 268
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:28:15.379: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:15.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:15.379: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:15.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Sep 19 12:28:15.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:15.379: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:15.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
Router#
*Sep 19 12:28:19.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:19.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654CDD0, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:19.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:19.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:19.375: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654CDD0, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:19.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 19 Sep 2012 12:28:15 GMT
CSeq: 1 INVITE
Content-Length: 268
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:28:19.379: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:19.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:19.379: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:19.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Sep 19 12:28:19.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:19.379: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:19.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
*Sep 19 12:28:20.147: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x4654D2E0,addr=10.0.99.100
Router#
*Sep 19 12:28:23.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Sep 19 12:28:23.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654CEF0, addr=10.0.99.221, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Sep 19 12:28:23.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:23.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:23.375: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654CEF0, addr=10.0.99.221, port=5061, connId=0 for UDP
*Sep 19 12:28:23.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 19 Sep 2012 12:28:19 GMT
CSeq: 1 INVITE
Content-Length: 268
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
a=ptime:10
*Sep 19 12:28:23.379: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:23.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:23.379: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4627A3B8
*Sep 19 12:28:23.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Sep 19 12:28:23.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:23.379: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:23.379: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.221,Port 5061, Transport 1, SentBy Port 5061
Router#
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Error/act_active_wait_ack: Out of retries
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:102, category:129
*Sep 19 12:28:27.375: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[19], src[6]
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(127) for incoming call
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DD90, addr=10.0.99.221, port=5061, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x410872CC
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4654DD90
*Sep 19 12:28:27.375: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DD90, addr=10.0.99.221, port=5061, connId=4 for UDP
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Sep 19 12:28:27.375: //19/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Sep 19 12:28:27.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4991589848@10.0.99.221:5061;user=phone SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1E2659
From: <sip:0001124957887603@10.0.99.29;user=phone>;tag=114FC0-1F24
To: <sip:4991589848@10.0.99.221:5061;user=phone>;tag=4095425038-3792786178-436258467-408012644
Date: Wed, 19 Sep 2012 12:28:23 GMT
Max-Forwards: 70
Timestamp: 1348057707
CSeq: 101 BYE
Content-Length: 0
*Sep 19 12:28:27.379: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Sep 19 12:28:27.379: //20/000000000000/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Sep 19 12:28:27.379: //20/000000000000/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Sep 19 12:28:27.383: //20/000000000000/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Sep 19 12:28:27.383: //20/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Sep 19 12:28:27.383: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DD90, addr=10.0.99.100, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x410872CC
*Sep 19 12:28:27.383: //20/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:27.383: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:27.383: //20/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4654DD90
*Sep 19 12:28:27.383: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DD90, addr=10.0.99.100, port=5060, connId=3 for UDP
*Sep 19 12:28:27.383: //20/000000000000/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Sep 19 12:28:27.383: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Sep 19 12:28:27.383: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.221:5061
*Sep 19 12:28:27.383: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4957887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1F1C07
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
*Sep 19 12:28:27.383: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4627A3B8
*Sep 19 12:28:27.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Contact: <sip:4991589848@10.0.99.221:5061;user=phone>
Content-Length: 0
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Info/sipSPIIcpifUpdate: CallState: 3 Playout: 0 DiscTime:116664 ConnTime 114193
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/State/sipSPIChangeState: 0x4627A3B8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g711alaw
Disconnect Cause (CC)    : 127
Disconnect Cause (SIP)   : 200
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 13
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4627A3B8 key=0e3a1c30025311e2a3c6001a64c75118@10.0.99.2210001124957887603
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
*Sep 19 12:28:27.387: //19/0E2E8C62A3C6/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4627A3B8 key=0e3a1c30025311e2a3c6001a64c75118@10.0.99.221114FC0-1F24
*Sep 19 12:28:27.391: //19/0E2E8C62A3C6/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Sep 19 12:28:27.391: //19/0E2E8C62A3C6/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4627A3B8
*Sep 19 12:28:27.395: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Sep 19 12:28:27.395: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:27.395: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
*Sep 19 12:28:27.395: //20/000000000000/SIP/Info/sipSPIIcpifUpdate: CallState: 3 Playout: 0 DiscTime:116665 ConnTime 114192
*Sep 19 12:28:27.395: //20/000000000000/SIP/State/sipSPIChangeState: 0x4627C64C : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Sep 19 12:28:27.395: //20/000000000000/SIP/Call/sipSPICallInfo:
*Sep 19 12:28:27.395: //20/000000000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec Bytes   : 20
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0
*Sep 19 12:28:27.395: //20/000000000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 14
Router#
*Sep 19 12:28:27.399: //20/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Sep 19 12:28:27.399: //20/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4627C64C key=45D1BE07-18C11E2-80158018-61678721@10.0.99.29
*Sep 19 12:28:27.399: //20/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Sep 19 12:28:27.399: //20/0E2E8C62A3C6/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4627C64C
Router#
*Sep 19 12:28:48.411: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.111:5061
*Sep 19 12:28:48.411: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Sep 19 12:28:48.415: //17/012C5B20A7A9/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x46275E90
*Sep 19 12:28:48.415: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4957815696@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.111:5061;rport;branch=z9hG4bK-3327884088-3792786178-436251047-2287060836
From: <sip:4996540000@10.0.99.111:5061;user=phone>;tag=513356033-3792786178-436251047-2287060836
To: <sip:4957815696@10.0.99.29;user=phone>;tag=10B508-12FA
Call-ID: 01319946025311e2a7a9001a64c75188@10.0.99.111
CSeq: 2 BYE
Max-Forwards: 70
Reason: MVTSLocal;cause=10;text="BYE received"
Content-Length: 0
*Sep 19 12:28:48.415: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.111,Port 5061, Transport 1, SentBy Port 5060
*Sep 19 12:28:48.415: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 19 12:28:48.415: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.111,Port 5061, Transport 1, SentBy Port 5061
*Sep 19 12:28:48.415: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[17], src[2]
*Sep 19 12:28:48.415: //17/012C5B20A7A9/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Sep 19 12:28:48.415: //17/012C5B20A7A9/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for incoming call
*Sep 19 12:28:48.415: //17/012C5B20A7A9/SIP/State/sipSPIChangeState: 0x46275E90 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Sep 19 12:28:48.419: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Transport/sipSPITransportSendMessage: msg=0x4654DD00, addr=10.0.99.111, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x41087578
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:48.419: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654DD00, addr=10.0.99.111, port=5061, connId=0 for UDP
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:118768 ConnTime 109917
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/State/sipSPIChangeState: 0x46275E90 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x46275E90
Calling Number           : 4996540000
Called Number            : 4957815696
Destn SIP Req Addr:Port  : 10.0.99.111:5061
Destn SIP Resp Addr:Port : 10.0.99.111:5061
Destination Name         : 10.0.99.111
*Sep 19 12:28:48.419: //17/012C5B20A7A9/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 18178
Destn  IP Port    (Media): 21538
Disconnect Cause (CC)    : 16
*Sep 19 12:28:48.423: //17/012C5B20A7A9/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 11
*Sep 19 12:28:48.423: //18/000000000000/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Sep 19 12:28:48.423: //18/000000000000/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Sep 19 12:28:48.423: //18/000000000000/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Sep 19 12:28:48.423: //18/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Sep 19 12:28:48.423: //18/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4654E2A0, addr=10.0.99.99, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x410872CC
*Sep 19 12:28:48.423: //18/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Sep 19 12:28:48.423: //18/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Sep 19 12:28:48.423: //18/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4654E2A0
*Sep 19 12:28:48.423: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4654E2A0, addr=10.0.99.99, port=5060, connId=1 for UDP
*Sep 19 12:28:48.423: //18/000000000000/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Sep 19 12:28:48.423: //18/000000000000/SIP/State/sipSPIChangeState: 0x46278124 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Sep 19 12:28:48.423: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 19 Sep 2012 12:28:48 GMT
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
CSeq: 2 BYE
*Sep 19 12:28:48.427: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:0001124957815696@10.0.99.99:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK20206B
To: <sip:0001124957815696@10.0.99.99>;tag=1689190644-3792785922-436270253-3629041508
Date: Wed, 19 Sep 2012 12:27:15 GMT
Call-ID: 2E36A5D4-18C11E2-80138018-61678721@10.0.99.29
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1348057728
CSeq: 102 BYE
Content-Length: 0
*Sep 19 12:28:48.427: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.99:5060
*Sep 19 12:28:48.427: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Contact: <sip:0001124957815696@10.0.99.99:5060>
Server: MERA MVTS3G v.4.4.0-15
Content-Length: 0
*Sep 19 12:28:48.431: //18/000000000000/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:118769 ConnTime 109916
*Sep 19 12:28:48.431: //18/000000000000/SIP/State/sipSPIChangeState: 0x46278124 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Sep 19 12:28:48.431: //18/000000000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x46278124
Called Number            : 0001124957815696
Destn SIP Req Addr:Port  : 10.0.99.99:5060
Destn SIP Resp Addr:Port : 10.0.99.99:5060
Destination Name         : 10.0.99.99
*Sep 19 12:28:48.431: //18/000000000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17106
Destn  IP Address (Media): 10.0.99.121
Destn  IP Port    (Media): 18600
*Sep 19 12:28:48.431: //18/000000000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 12
Router#
*Sep 19 12:28:48.431: //18/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Sep 19 12:28:48.431: //18/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x46278124 key=2E36A5D4-18C11E2-80138018-61678721@10.0.99.29
*Sep 19 12:28:48.431: //18/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Sep 19 12:28:48.431: //18/012C5B20A7A9/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 46278124
In my previos discussion Danielle Giordany tried to help, but he disappeared.
May somebody help me in my situation? I give all needed additional information.
Kind regards,
Ellad Yatsko
8 Replies 8
Hi Ellad.
Why don't try to use the 2811 as a SIP signalling proxy only?
In this way the media (RTP or T.38) will be handled only from the two MERA SoftSwitch.
To do this you must enable CUBE on your 2811 and use these special commands:
voice service voip
     media flow-around
     allow-connections sip to sip
     signaling forward unconditional
     sip
       rel1xx disable
       header-passing
       midcall-signaling passthru
       pass-thru headers unsupp
       pass-thru content unsupp
       pass-thru content sdp
I don't remember if we have already try this solution.
Regards.
Hello Danielle!
I'm glad to see you! :-) Sure! I'll try it, but... It would be better if all traffic is handled by transit Cisco. On other hand we encounter error during FAX re-invite. That is during the signalling session, in't it? Or do I imagine the process incorrectly?
By the way, I tried this but some commands are not available. Cisco "swears". :-)
Kind regards,
Ellad Yatsko
Hi, im having a similar issue with T.38, what was the exact version of code that you upgraded to?
Thanks in advance,
Tom.....
Hello Tom!
We didn't try it with 2811, we got result on initial 1760 (see the similar topic for 1760). We upgraded on "voice" T-version. But I think "adventerprice" would be appropriate too. The only thing that memory requirements should be met.
Kind regards,
Ellad
Ellad Yatsko
Problem was resolved by upgrading IOS on T(est)-version.
In mainstream version SIP-to-SIP switchover in T.38 mode doesn't work.
Special thanks and glory to JTR!
Kind regards,
Ellad
The letter T in IOS filename does not means Test.
Whatever it means, it only designantes the new versions being release.
Whatver it means, it only designantes the new versions being release.
Hello Paolo!
It doesn't matter as you understand. Most importantly it works! :-) But it would be considerably more useful if you decrypt it for all who reads this topic. :-) Though... Nevermind! :-)
Kind regards,
Ellad
It used to to indicate Technology.
