Command to check dial-peer
bilaljaved
Dear Sir,
If i have three dial peers at incoming call leg for pots then what is the command to see which pots dial peer is being read by the device.
23 Replies 23
You can test your dial-peer with the command show dialplan number xxxphone numberxxx.
If the call is active you can check used dial-peer with the command show voice call status.
C2xxxx#show voice call status
CallID     CID  ccVdb      Port        DSP/Ch  Called #   Codec    Dial-peers
0x24EAF    39E6 0x84341218 1/0:15.1    7/1    *03xxxxx None     1000/200
1 active call found
Regard.
In addition to Daniele's feedback, the "debug voip dialpeer detail" command will show you real time what string your dialing and the matching dialpeer of that string. See below bolded sections below:
295528: Feb  7 16:07:13.710 UTC: //-1/0014ACCA0417/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=913107950003
295529: Feb  7 16:07:13.710 UTC: //-1/0014ACCA0417/DPM/dpMatchCore:
   Dial String=913107950003, Expanded String=913107950003, Calling Number=
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
295530: Feb  7 16:07:13.710 UTC: //-1/0014ACCA0417/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=91206 Is Matched
Sirs,
Can you plz guide me whats going on is here. iwant that calls from my ANI will always go to voip dial-peer 9002 but its reading 1001.  Can you plz guide me for that.
My configs are :
dial-peer voice 1001 voip
description Towards Advance VOIP
translation-profile outgoing national
destination-pattern .T
voice-class codec 1002
session protocol sipv2
session target ipv4:221.120.227.74
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 9002 voip
description Office PRI Diversion
translation-profile outgoing office
preference 1
answer-address 512112152
voice-class codec 1001
session target ipv4:221.120.212.197
dtmf-relay rtp-nte
fax rate 9600
The O/P of debug dial-peer is :
6w5d: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=512112152
6w5d: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
6w5d: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=512112152T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_FAX
6w5d: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3830,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=1001,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=9002,Peer Info Type=DIALPEER_INFO_SPEECH)
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=512112152
   Result=-1
   Dial String=1256, Expanded String=1256, Calling Number=
   Result=Success(0); Outgoing Dial-peer=1001 Is Matched
   Result=Success(0); Outgoing Dial-peer=9002 Is Matched
   Dial String=1256, Expanded String=1256, Calling Number=1256T
6w5d: //-1/87A085DEA7C6/DPM/dpMatchCore:
6w5d: //-1/87A085DEA7C6/DPM/MatchNextPeer:
   Dial String=512112152, Expanded String=512112152, Calling Number=
plz guide i need that my ANI 512112152 always read 9002 voip dial-peer and all other ANIs read 1001 dial-peer.
regards,
bilal
You must user "answer-address" command on dial-peer.
More info at this link: http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Regards.
i used answer address command on 9002 dial-peer but still not reading that dial-peer
dtmf-relay rtp-nte
fax rate 14400
preference 1
dtmf-relay rtp-nte
fax rate 9600
Can you plz check it again. Thanks
Bilal
Remove the destination-pattern and the preference option to leave answer-address only.
Add the output of debug voip dialpeer.
Thanks.
removed both these things and now output is :
dtmf-relay rtp-nte
fax rate 9600
   Result=-1
   Result=-1
6w5d: //-1/D4BB60AA8B65/DPM/dpMatchCore:
6w5d: //-1/D4BB60AA8B65/DPM/MatchNextPeer:
regards,
bilal
A common misunderstanding with voice dial peers is that they are only configured for outbound functionality, that is, to map a dial string to a remote network device (with the Cisco IOS commands destination-pattern and session target) or a POTS voice port (with the Cisco IOS commands destination-pattern and port).
In order to match outbound dial peers, the router or gateway uses the dial peer destination-pattern called_number command.
In this case I use a trick.
I create an incoming dial-peer to match the answer-address.
This dial-peer has a translation rule to add a prefix to called number.
So, I create a second outbound dial-peer with destination-pattern that matches the prefix added first.
dial-peer voice 1012 voip
description INCOMING DP - (add prefix 2299)
translation-profile incoming XLATE_NUM_B
answer-address 290
modem passthrough nse codec g711alaw
session transport udp
dtmf-relay rtp-nte
codec g711alaw
fax rate 14400
fax protocol t38 ls-redundancy 2 hs-redundancy 2 fallback pass-through g711alaw
no vad
voice translation-profile XLATE_NUM_B
translate called 15
voice translation-rule 15
rule 1 /^\([0-9]\)/ /2299\1/
dial-peer voice 102 voip
description OUT_SIP (strip prefix 2299)
translation-profile outgoing STRIP_PREFIX_2299
huntstop
preference 2
destination-pattern 2299T
session target dns:xxx
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
fax protocol pass-through g711alaw
no vad
voice translation-profile STRIP_PREFIX_2299
translate called 11
voice translation-rule 11
rule 1 /^2299/ //
Regards.
Dear Daniele,
Thanks for explained reply.
i implented it but no success uptil now.
Let me explain my scenario in short.
Actually my call is coming from PSTN and i recived that call from ANI 512112152 on pots dial peer that is :
dial-peer voice 3820 pots
tone ringback alert-no-PI
description ### FOR ORIGINATION POTS DIALPEER  ###
direct-inward-dial
port 7/3:D
Also i used your trick but no success :
dial-peer voice 9003 voip
translation-profile incoming add-prefix
modem passthrough nse codec g711ulaw
dtmf-relay rtp-nte
fax rate 14400
dial-peer voice 9004 voip
huntstop
preference 2
session target ipv4:xxxx
dtmf-relay rtp-nte
fax rate 9600
but still its always going on 1001 DP :
preference 2
session target ipv4:yyyy
dtmf-relay rtp-nte
fax rate 14400
i took also voip debugs and these are pasted below:
Dial String=1256C, Expanded String=1256C, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
6w6d: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
6w6d: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
6w6d: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
6w6d: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=3820 Is Matched
   Result=Success(0); Incoming Dial-peer=9003 Is Matched
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=1256C
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3810,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3820,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=9003,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=9004,Peer Info Type=DIALPEER_INFO_SPEECH)
   Result=-1
   Result=-1
   Result=-1
but its not reading voip 9004. Can you please guide me  furthur that what should i do now so that my calls from ANI 512112152  will read only 9004 and not 1001 which its reading always.
Thankyou very much
regards,
bilal
Can you add the output of command "debug ccapi inout"?
Regards.
Dear Daniel,
Here is O/P of ccapi :
cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
7w0d: //-1/557A0F1DA443/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x670C6BD4, Call Info(
   Calling Number=512112152,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1256C(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3820, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
7w0d: //-1/557A0F1DA443/CCAPI/ccCheckClipClir:
   In: Calling Number=512112152(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=512112152(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
7w0d: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
7w0d: :cc_get_feature_vsa malloc success
7w0d:  cc_get_feature_vsa count is 37
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723403368,feature_id:232263
7w0d: //232263/557A0F1DA443/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=512112152(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1256C(TON=Subscriber, NPI=ISDN))
7w0d: //232263/557A0F1DA443/CCAPI/cc_process_call_setup_ind:
   Event=0x66BAA420
7w0d: //232263/557A0F1DA443/CCAPI/ccCallSetContext:
   Context=0x67FB03A8
   >>>>CCAPI handed cid 232263 with tag 3820 to app "_ManagedAppProcess_Default"
7w0d: //232263/557A0F1DA443/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
7w0d: //232263/557A0F1DA443/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3810, Params=0x67A52F04, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
7w0d: //232263/557A0F1DA443/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=1256C, Digit Strip=TRUE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=557A0F1D-54B7-11E1-A443-0003BAA7801F, Outgoing Dial-peer=3810
7w0d: //232263/557A0F1DA443/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
7w0d: //232263/557A0F1DA443/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x670C6BD4, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=512112152,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1256C(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3810, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
7w0d:  cc_get_feature_vsa count is 38
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723424968,feature_id:232264
7w0d: //232264/557A0F1DA443/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
7w0d: //232264/557A0F1DA443/CCAPI/ccCallSetContext:
   Context=0x67A52EB4
7w0d: //232263/557A0F1DA443/CCAPI/ccSaveDialpeerTag:
7w0d: //232264/557A0F1DA443/CCAPI/cc_api_call_proceeding:
   Interface=0x670C6BD4, Progress Indication=NULL(0)
7w0d: //232264/557A0F1DA443/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x670C6BD4, Call Id=232264
   Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
7w0d: //232263/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
7w0d: //232264/557A0F1DA443/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=232264
7w0d: //232264/557A0F1DA443/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
7w0d: //232264/557A0F1DA443/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
7w0d: //232264/557A0F1DA443/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x670C6BD4, Tag=0x0, Call Id=232264,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
7w0d: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
7w0d: :cc_free_feature_vsa freeing 66B960C0
7w0d:  vsacount in free is 37
   Outgoing Dial-peer=1001, Params=0x6826CC7C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
   Destination Pattern=.T, Called Number=1256C, Digit Strip=FALSE
   Guid=557A0F1D-54B7-11E1-A443-0003BAA7801F, Outgoing Dial-peer=1001
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   Interface=0x666A6238, Interface Type=3, Destination=, Mode=0x0,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1001, Call Count On=FALSE,
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723424968,feature_id:232265
7w0d: //232265/557A0F1DA443/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
7w0d: //232265/557A0F1DA443/CCAPI/ccCallSetContext:
   Context=0x6826CC2C
7w0d: //232265/557A0F1DA443/CCAPI/cc_api_call_proceeding:
   Interface=0x666A6238, Progress Indication=NULL(0)
7w0d: //232265/557A0F1DA443/CCAPI/cc_api_call_connected:
   Interface=0x666A6238, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
7w0d: //232263/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x67F46164, callID1=0x38B47, callID2=0x38B49, tag=0x0)
7w0d: //232263/557A0F1DA443/CCAPI/ccConferenceCreate:
   Conference Id=0x67F46164, Call Id1=232263, Call Id2=232265, Tag=0x0
7w0d: //232263/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x19A57, Source Interface=0x670C6BD4, Source Call Id=232263,
   Destination Call Id=232265, Disposition=0x0, Tag=0xFFFFFFFF
7w0d: //232265/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
7w0d: cc_api_get_xcode_stream : 4381
7w0d: //232265/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x19A57, Source Interface=0x666A6238, Source Call Id=232265,
   Destination Call Id=232263, Disposition=0x0, Tag=0x0
7w0d: //232263/557A0F1DA443/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x19A57, Destination Call Id=232265)
7w0d: //232265/557A0F1DA443/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x19A57, Destination Call Id=232263)
7w0d: //232263/557A0F1DA443/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=232265, Source Call Id=232263,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
7w0d: //232265/557A0F1DA443/CCAPI/cc_api_caps_ind:
   Destination Interface=0x670C6BD4, Destination Call Id=232263, Source Call Id=232265,
   Caps(Codec=0x4, Fax Rate=0x80, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=1)
7w0d: //232265/557A0F1DA443/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_14400(0x80), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=7838)
7w0d: //232263/557A0F1DA443/CCAPI/cc_api_caps_ack:
7w0d: //232263/557A0F1DA443/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x19A57, Call Id1=232263, Call Id2=232265
7w0d: //232263/557A0F1DA443/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
7w0d: //232260/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 3 to dstCallId 0x38B46
7w0d: //232263/557A0F1DA443/CCAPI/cc_api_voice_mode_event:
   Call Id=232263
   Call Entry(Context=0x67FB03A8)
7w0d: //232260/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x38B46
7w0d: //232263/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x38B49
7w0d: //232263/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
   Consume mask is not set. Relaying Digit 3 to dstCallId 0x38B49
   Consume mask is not set. Relaying Digit 4 to dstCallId 0x38B49
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x38B49
   Consume mask is not set. Relaying Digit 8 to dstCallId 0x38B46
   Consume mask is not set. Relaying Digit 6 to dstCallId 0x38B46
   Consume mask is not set. Relaying Digit 9 to dstCallId 0x38B49
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x38B46
   Consume mask is not set. Relaying Digit 8 to dstCallId 0x38B49
   Consume mask is not set. Relaying Digit 4 to dstCallId 0x38B46
   Consume mask is not set. Relaying Digit # to dstCallId 0x38B49
   Consume mask is not set. Relaying Digit # to dstCallId 0x38B46
7w0d: //-1/5B15F979A457/CCAPI/cc_api_display_ie_subfields:
also the O/P of
RWPCisco-03#show voice call sta
0x38C3D    39C5     0x670C6BD4    7/3.13           3/0:3       1256C      g729r8    3820/1001
Please guide furthur.
The problem is the outbound dial-peer match and not on incoming DP as I imagined.
The literature says:
Outbound dial-peer matching is completed on a digit-by-digit basis. Therefore, the router or
gateway checks for dial-peer matches after receiving each digit and then routes the call when a
full match is made.
The router or gateway matches outbound dial peers in the following order:
1. The router or gateway uses the dial peer destination-pattern command to determine how to
route the call.
2. The destination-pattern command routes the call in the following manner:
On POTS dial peers, the port command forwards the call.
On VoIP dial peers, the session target command forwards the call.
3. Use the show dialplan number string command to determine which dial peer is matched to a
specific dialed string. This command displays all matching dial peers in the order that they are
used.
How the Router or Gateway Matches Inbound Dial Peers
1. The router or gateway attempts to match the called number of the call setup request with the
configured incoming called-number of each dial peer.
2. If a match is not found, the router or gateway attempts to match the calling number of the call
setup request with answer-address of each dial peer.
3. If a match is not found, the router or gateway attempts to match the calling number of the call
setup request to the destination-pattern of each dial peer.
4. The voice port uses the voice port number associated with the incoming call setup request to
match the inbound call leg to the configured dial peer port parameter.
5. If multiple dial peers have the same port configured, then the router or gateway matches the
first dial peer added to the configuration.
6. If a match is not found in the previous steps, then the default is dial peer 0.
So outbount DP match is based on destination-pattern and so we can modify the called number to match a specific DP.
Your incoming DP is always the pots 3820 DP.
What are the answer-address of incoming calls received on this dial-peer?
Is only 512112152? Or can be different?
If the incoming calls has always the 512112152 calling number, you can move the translation rule that add special prefix to this pots DP.
If not we can try to create a new incoming pots dial-peer for specific answer-address.
This is the idea:
description ### FOR 512112152 called  ###
direct-inward-dial
port 7/3:D
dial-peer voice xxx pots
answer-address .
direct-inward-dial
port 7/3:D
huntstop
preference 2
dtmf-relay rtp-nte
fax rate 9600
preference 2
dtmf-relay rtp-nte
fax rate 14400
Let me know the result.
Regards.
Dear Daniele,
With your help i have manage to perform the task successfully and call is moving out from DP 9004 for my test ANI 512112152 and for rest of numbers its reading DP 1001. The configs are :
preference 2
dtmf-relay rtp-nte
fax rate 14400
dial-peer voice 3810 pots
direct-inward-dial
port 7/3:D
dial-peer voice 3830 pots
description ### FOR TERMINATION POTS DIALPEER #####
translation-profile outgoing national-outgoing
destination-pattern 92101T
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 7/0:D
description ### FOR ORIGINATION POTS DIALPEER ADDIng PREFIX ###
direct-inward-dial
port 7/3:D
huntstop
preference 2
dtmf-relay rtp-nte
fax rate 9600
translate called 11
voice translation-profile add-prefix
translate called 15
rule 1 /^2299/ //
Thanks.
Now problem is i have multiple ANI to be shifted on DP 9004 through 3820 like we did for our test ANI 512112152.
ANIS are
512197115
514411810
for this i used a trcik but its helping. i create translation rule for calling number and apply that on my incoming DP 3820 like :
voice translation-rule 16
rule 1 /^514411810/ /514411810/
rule 2 /^512112152/ /512112152/
rule 3 reject //
translate calling 16
translate called 15
and in POTS DP i removed answer address and used destination pattern in both pots that is 3810 and 3820.
direct-inward-dial
port 7/3:D
preference 1
direct-inward-dial
port 7/3:D
Also O/P of debug ccapi is :
>>>>CCAPI handed cid 245250 with tag 3810 to app "_ManagedAppProcess_Default"
7w0d: //245250/B29445809802/CCAPI/ccCallProceeding:
7w0d: //245250/B29445809802/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3810, Params=0x67EEA190, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
7w0d: //245250/B29445809802/CCAPI/ccCheckClipClir:
   Guid=B2944580-54EE-11E1-9802-0003BAA7801F, Outgoing Dial-peer=3810
7w0d: //245250/B29445809802/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
7w0d: //245250/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
7w0d:  cc_get_feature_vsa count is 46
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723410928,feature_id:245251
7w0d: //245251/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
7w0d: //245251/B29445809802/CCAPI/ccCallSetContext:
   Context=0x67EEA140
7w0d: //245250/B29445809802/CCAPI/ccSaveDialpeerTag:
7w0d: //245251/B29445809802/CCAPI/cc_api_call_proceeding:
7w0d: //245251/B29445809802/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x670C6BD4, Call Id=245251
7w0d: //245250/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
7w0d: //245251/B29445809802/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=245251
7w0d: //245251/B29445809802/CCAPI/ccCallDisconnect:
7w0d: //245251/B29445809802/CCAPI/cc_api_get_transfer_info:
7w0d: //245251/B29445809802/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x670C6BD4, Tag=0x0, Call Id=245251,
7w0d: :cc_free_feature_vsa freeing 66B929E8
7w0d:  vsacount in free is 45
   Outgoing Dial-peer=3820, Params=0x6816F36C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
   Guid=B2944580-54EE-11E1-9802-0003BAA7801F, Outgoing Dial-peer=3820
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3820, Call Count On=FALSE,
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723410928,feature_id:245252
7w0d: //245252/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
7w0d: //245252/B29445809802/CCAPI/ccCallSetContext:
   Context=0x6816F31C
7w0d: //245252/B29445809802/CCAPI/cc_api_call_proceeding:
7w0d: //245252/B29445809802/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x670C6BD4, Call Id=245252
7w0d: //245252/B29445809802/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=245252
7w0d: //245252/B29445809802/CCAPI/ccCallDisconnect:
7w0d: //245252/B29445809802/CCAPI/cc_api_get_transfer_info:
7w0d: //245252/B29445809802/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x670C6BD4, Tag=0x0, Call Id=245252,
   Outgoing Dial-peer=1001, Params=0x67A5944C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
   Guid=B2944580-54EE-11E1-9802-0003BAA7801F, Outgoing Dial-peer=1001
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723410928,feature_id:245253
7w0d: //245253/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
7w0d: //245253/B29445809802/CCAPI/ccCallSetContext:
   Context=0x67A593FC
7w0d: //245253/B29445809802/CCAPI/cc_api_call_proceeding:
7w0d: //245253/B29445809802/CCAPI/cc_api_call_connected:
   Connection Handle=0
7w0d: //245250/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6803E160, callID1=0x3BE02, callID2=0x3BE05, tag=0x0)
7w0d: //245250/B29445809802/CCAPI/ccConferenceCreate:
   Conference Id=0x6803E160, Call Id1=245250, Call Id2=245253, Tag=0x0
7w0d: //245250/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE67, Source Interface=0x670C6BD4, Source Call Id=245250,
   Destination Call Id=245253, Disposition=0x0, Tag=0xFFFFFFFF
7w0d: //245253/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
7w0d: //245253/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE67, Source Interface=0x666A6238, Source Call Id=245253,
   Destination Call Id=245250, Disposition=0x0, Tag=0x0
7w0d: //245250/B29445809802/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1AE67, Destination Call Id=245253)
7w0d: //245253/B29445809802/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AE67, Destination Call Id=245250)
7w0d: //245250/B29445809802/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=245253, Source Call Id=245250,
7w0d: //245253/B29445809802/CCAPI/cc_api_caps_ind:
   Destination Interface=0x670C6BD4, Destination Call Id=245250, Source Call Id=245253,
7w0d: //245253/B29445809802/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=3409)
7w0d: //245250/B29445809802/CCAPI/cc_api_caps_ack:
7w0d: //245250/B29445809802/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1AE67, Call Id1=245250, Call Id2=245253
7w0d: //245250/B29445809802/CCAPI/ccCallConnect:
7w0d: //245250/B29445809802/CCAPI/cc_api_voice_mode_event:
   Call Id=245250
   Call Entry(Context=0x67A5203C)
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_call_alert:
   Interface=0x66BF1B54, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
7w0d: //245246/BB9E397385B3/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
7w0d: //245246/BB9E397385B3/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=245246
7w0d: //245246/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6803DF20, callID1=0x3BDFE, callID2=0x3BDFF, tag=0x0)
7w0d: //245246/BB9E397385B3/CCAPI/ccConferenceCreate:
   Conference Id=0x6803DF20, Call Id1=245246, Call Id2=245247, Tag=0x0
7w0d: //245246/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
7w0d: //245246/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE68, Source Interface=0x666A6238, Source Call Id=245246,
   Destination Call Id=245247, Disposition=0x0, Tag=0x0
7w0d: //245247/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE68, Source Interface=0x66BF1B54, Source Call Id=245247,
   Destination Call Id=245246, Disposition=0x0, Tag=0xFFFFFFFF
7w0d: //245246/BB9E397385B3/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1AE68, Destination Call Id=245247)
7w0d: //245247/BB9E397385B3/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AE68, Destination Call Id=245246)
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=245246, Source Call Id=245247,
7w0d: //245246/BB9E397385B3/CCAPI/cc_api_caps_ind:
   Destination Interface=0x66BF1B54, Destination Call Id=245247, Source Call Id=245246,
7w0d: //245246/BB9E397385B3/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=9094)
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_caps_ack:
7w0d: //245246/BB9E397385B3/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1AE68, Call Id1=245246, Call Id2=245247
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_voice_mode_event:
   Call Id=245247
   Call Entry(Context=0x67A5DC54)
7w0d: //245250/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x3BE05
7w0d: //245250/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
   Consume mask is not set. Relaying Digit 3 to dstCallId 0x3BE05
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x3BE05
7w0d: //245215/A5E723098565/CCAPI/cc_api_call_cut_progress:
   Interface=0x66BF1B54, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=4
   Call Entry(Responsed=TRUE)
7w0d: //245214/A5E723098565/CCAPI/ccCallProgIndProgress:
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_call_alert:
   Interface=0x66BF1B54, Progress Indication=INBAND(8), Signal Indication=NOT PRESENT(255)
7w0d: //245248/BBEE2D3985B8/CCAPI/ccCallAlert:
7w0d: //245248/BBEE2D3985B8/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=245248
7w0d: //245248/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6803DCE0, callID1=0x3BE00, callID2=0x3BE01, tag=0x0)
7w0d: //245248/BBEE2D3985B8/CCAPI/ccConferenceCreate:
   Conference Id=0x6803DCE0, Call Id1=245248, Call Id2=245249, Tag=0x0
7w0d: //245248/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
7w0d: //245248/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE69, Source Interface=0x666A6238, Source Call Id=245248,
   Destination Call Id=245249, Disposition=0x0, Tag=0x0
7w0d: //245249/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE69, Source Interface=0x66BF1B54, Source Call Id=245249,
   Destination Call Id=245248, Disposition=0x0, Tag=0xFFFFFFFF
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1AE69, Destination Call Id=245249)
7w0d: //245249/BBEE2D3985B8/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AE69, Destination Call Id=245248)
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=245248, Source Call Id=245249,
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_api_caps_ind:
   Destination Interface=0x66BF1B54, Destination Call Id=245249, Source Call Id=245248,
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=9578)
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_caps_ack:
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1AE69, Call Id1=245248, Call Id2=245249
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x3BE05
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_voice_mode_event:
   Call Id=245249
   Call Entry(Context=0x67FABB50)
   Consume mask is not set. Relaying Digit 7 to dstCallId 0x3BE05
7w0d: //245254/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
7w0d: //-1/BEE39F2085C5/CCAPI/cc_api_display_ie_subfields
Please guide so that these other Ani will also follows 9004 DP to out to xxxx.
Bilal
Can you add more specific dial-peers with answer-address for your ANIs?
Can you use special char in answer-address?
something like
answer-address 51[2,4][1,4][1,9][1,2,7][1,8][1,5][0,2,5]
or
answer-address 51.......
Regards.
